Old 12-05-2005, 02:04 AM   #856
Sp Racer's Avatar
is the crankshaft and rear bearing of the tz compatible to the os tr
No , they are different, the TZ is bigger
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 12-05-2005, 07:33 AM   #857
Default Leaking problem
Hi all!
Does anyone had leaking problem on the TZ 5-port engine?
Mine did but could not find out which part of the engine!
Can anyone help me?
MTX4 is offline   Reply With Quote
Old 12-06-2005, 10:28 AM   #858
Seisick's Avatar
Originally Posted by MTX4
Hi all!
Can anyone help me?
front bearing for sure, mine lasted a gallon and then started leaking, I changed for and koyo bearing that costs 4 bucks, with some sleeve retainer in inner side, no more leaking again!
7x17 is the size for the front bearing
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 12-07-2005, 02:54 PM   #859
Send a message via MSN to Krasi_5000
hey guys, I would like to say I just got a OS .12 TZ 3 port. I ordered it along with some other stuff for my ntc3 and i just installed the clutch on it. It looks like a sweeeeeeeeet engine I can't wait to do break-in...but its gonna be a few months since its cold already and i aint doing it in the cold. Looks good...i will see how it performs soon enough
Krasi_5000 is offline   Reply With Quote
Old 12-07-2005, 07:23 PM   #860
HEY GUYS BEEN WONDERING WHAT % NITRO YOU GUYS RUNNING? AND IF RUNNING 30% ARE YOU SHIMMING ENGINES? WHAT FUEL? RUNNING TEMPS?
IM RUNNIG 30% ROCKET SCIENCE WITH TEMPS IN 200-230 RANGE WITH NO SHIMMING.
Ahhh the smell of nitro in the morning!
Brooklyn Hobbies Team Driver
[url]www.brooklynhobbies.com[/url]
Team Trinity
[url]www.teamtrinity.com[/url]
Gary Figueroa
GFIGUEROA is offline   Reply With Quote
Old 12-07-2005, 09:55 PM   #861
Trader Rating: 44 (100%+)
good article here:
http://www.rchobbies.org/engine-tuning.htm
you can check for leaks yourself ..
Hi all!
Can anyone help me?
wyl03 is offline   Reply With Quote
Old 12-07-2005, 10:04 PM   #862
rcabj's Avatar
thanks
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 12-07-2005, 10:48 PM   #863
moot's Avatar
no shimming on 30% but tried 40% but that needs shims.
moot is offline   Reply With Quote
Old 12-13-2005, 03:49 AM   #864
What is the size of TZR12 front and rear bearing?
A380 is offline   Reply With Quote
Old 12-13-2005, 02:58 PM   #865
which mugen pipe (part no. pls) is good for the TZ3?
how about the mielke pipe? a good match for TZ3?
Old 12-14-2005, 09:25 PM   #866
Default head shim?
How much head clearance are you guys running with 25% nitro? os .12 5 ports.Thx.
hotman is offline   Reply With Quote
Old 12-14-2005, 10:14 PM   #867
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Anyone can give me advice of a good pipe for the OS .12 TZ 3 port Turbo ? ... i was thinking about the OS 1040 but its comes up to US$ 104 !!
thanks in advance,
Pat
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 12-14-2005, 11:06 PM   #868
Just thought i might let you guys know that a myself, and a friend bought 2 TZs and raced them for the first time last sunday. In the A main final, we finished 1st and second respectively but as he was crossing the line, his conrod snapped in half. When i got home, i opened up for a quick look inside of mine, and everything seemed OK.
A couple of days later, i tried to put the flywheel and clutch back on the engine, and found that as soon as i tighten the clutch nut, i cant spin the flywheel! Im suspecting that there is a problem with the front bearing.
Considering that these 2 engines are new, run on 16%, not lean, with .30mm of head clearance, and broken in with heat cycling (as we do with our Novas), this is not acceptable. Our Nova based engines work a lot harder, are very quick, and last for much longer!
Lucky these OS gimmicks are as cheap as they are. This is my first and last OS...
NJ
Rody is offline   Reply With Quote
Old 12-15-2005, 12:57 AM   #869
moot's Avatar
funny thing is,i leaned the crap out of mine,ran 30% for 20 litres then started using 40%. at 23lt i decided to blow it up.full rpm on the starter box with 40% it died after 2 minutes.well,it didnt it ran out of fuel.put another tank in and full rpm again. got half way through that and the bottom of the piston skirt broke off. thats it! rod still looks in good condition
Old 12-15-2005, 02:00 PM   #870
Er, why would u want to do that?
Helping OS with some product destructive testing?
NJ mind if I ask where u got ur TZ3s from?
