Old 11-22-2005, 11:53 PM   #841
Sp Racer's Avatar
Thumbs up
surikan ran a zac modified novarossi at the winternats
I had to look twice, it did look like a TZ but it was definitely not an OS.
I used one at the winterchamps, I'll tell you, HP was NOT the problem!
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 11-23-2005, 07:34 AM   #842
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Originally Posted by rcabj
i am almost certain to get the tz3 port... i might also get a spare 5port p/s just in case i need them (heard the p/s is just a drop in to both motors)....
Youll need also the crankshaft for the 5 port if you want to do that.
Riketsu is offline   Reply With Quote
Old 11-23-2005, 12:33 PM   #843
Rapid Roy's Avatar
Originally Posted by Krasi_5000
heheh thanks for the quick reply. Yeah i was pretty sure the OS would last longer but they both seem like such awsome engines and its only $50 difference in price so i don't care about that. And i have seen both run and my local tracks and the both go rocket fast and i talked to the drivers and they both said they were awsome. Im ordering right now, will let you know which one i get.
EDIT: Well i just ordered it! I got the Novarossi N12LL3, MX-3 Synthesized and 4 ellegi pairs...a 37 shore, and 40 fronts and 42 and 45 rears. Now i just can't wait for them to come
I don't know what really works at your track, but the rear foams are almost always softer then the fronts and you ordered the opposite
Rapid Roy is offline   Reply With Quote
Old 11-23-2005, 01:01 PM   #844
Send a message via MSN to Krasi_5000
well every other engine on the track is either a LL3 or a TZ so i don't think thats a problem. Both local tracks are pretty short and technical with a like 60 foot straight. Last season all i ran was softer if front harder in rear like 35/37 or 40/42 and it always stuck like it was on rails. I actually got that combo cause the pro level racers said that softer in the front is better. I never really expirimented cause i didnt have much $$ but i think this season i will put harder infront and softer in rear and see how it works.
Krasi_5000 is offline   Reply With Quote
Old 11-23-2005, 06:37 PM   #845
rcabj's Avatar
shucks... if that is the case then i have to reconsider the options...
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 11-23-2005, 06:54 PM   #846
Can Nova plugs be used on the TZ?
Rody is offline   Reply With Quote
Old 11-23-2005, 07:39 PM   #847
Riketsu's Avatar
Someone on this thread said no, I think. Compare the conical part of the plug, if its the same, then yes, you can use them. Only mega picco plugs are longer where the conical end is.
Old 11-23-2005, 09:11 PM   #848
moot's Avatar
yes. i have used lrp,sirio,os,and novarossi plugs and havent had a problem with any of them.
moot is offline   Reply With Quote
Old 11-24-2005, 12:08 AM   #849
Trader Rating: 13 (93%+)
Default pipe for os tz 3 port and v one rrr
hey team
i just wanted to know what pipe you guys have found working really good with thee engines ?
im after a 1 piece pipe for the v one rrr and os tz, must be legal 5.2mm stinger
thanks
John
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 11-24-2005, 09:53 AM   #850
Seisick's Avatar
Originally Posted by mrgsr
hey team
thanks
John
mugen shimo pipe, os 1040 and skyline vr12 are the best choices for the tz, got mugen and Im very happy with it!
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 11-24-2005, 09:58 AM   #851
Seisick's Avatar
anyone has tried the os eb mod that tower sells for 320? well actually less than 300 if considering the online coupon
HobbymaniA
GoT MuGeN?
Old 11-24-2005, 12:34 PM   #852
nitrothugg's Avatar
Exclamation switching between 3 and 5 ports requires no mods
you can drop the 5 port p/s set into a 3 port with no mods. i have flipped between both. i bought the 3 port version and wanted to try the 5 port and didnt have no issues. the 5 port was actually easier to break in.
nitrothugg is offline   Reply With Quote
Old 11-24-2005, 12:41 PM   #853
nitrothugg's Avatar
just took a look, i wonder if you can buy the individual parts in the future?
Old 11-24-2005, 01:05 PM   #854
Riketsu's Avatar
Theres no doubt that the 5 port p/s will fit in the crankcase. But I believe the cuts made to the 5 port crankshaft isnt the same as the ones made to the 3 port. Port timing changes so it affects the overall performance of the engine, and I believe it isnt a good factor.
Old 12-05-2005, 12:40 AM   #855
rcabj's Avatar
Default crankshaft / rear bearing
is the crankshaft and rear bearing of the tz compatible to the os tr...thanks
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
