Old 10-27-2005, 07:59 AM   #796
JLock's Avatar
Originally Posted by Chaya
Thanks Bro, Appreciate it very much. . .
Have any one tried this break in process???
I have tried a variation of this. I have done three tanks on idle, keeping my operating temperature between 175F to 200F degrees, with occasionally letting it get up to 215F degrees before putting a fan on it to cool it down. After that, I run the next three tanks rolling the car slowly in a parking lot/driveway, checking the temps constantly. Once I finish those three tanks, I run the next two to three under quasi-race conditions, fine tuning it along the way. I tried this on my OS 12tz and it ran a 40 minute main and came off the track at the end at a cool 196F degrees with plenty of power (could have tweaked the settings a bit more for some extra power).
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 10-27-2005, 08:35 AM   #797
I've used Josh's break in process on my OS 18 CVR engine, and loved it. I was able to break in the truck much faster than the usual "idle for a few tanks, blah blah blah" method. Also, after the break in, the engine just flat out rips now. I finished the break in process that Josh outlines in about 3-4 hours, that's including breaks for cool down. Its an awesome method and my CVR has been bulletproof.
For my Mugen X12 engine, I've used a different method before I even read Josh's article. What I have done in the past at my local track, is run it up to 2/3 throttle in short 3-4 second bursts for the first 4 tanks, and then lean out with each subsequent tank, up to 7 tanks. Then I would start doing full throttle pulls, each about 3-4 seconds, up to the 10th tank. From there I would feel the engine is fully broken in, and just tune for high performance on the 11th tank and so forth. With this method, I have 2 gallons thru my Mugen X12, and its a beast. Even to this day, I beat OS 12 TZ 5 ports on our back straight (150 ft straightaway). The power range of this engine is unbelievable. And the engine STILL holds a tune each day.
I will be using Josh's method when breaking in my new OS 12 TZ 5 port engine (which needs a Mugen MTX4 by the way ), as well as any new engines I purchase. Its a great break in method and just flat out works.
Originally Posted by Secret_weapon
snowboardgeek1 is offline   Reply With Quote
Old 10-27-2005, 05:54 PM   #798
Chaya's Avatar
To Mr snowboardgeek1 & JLock,
Tnx for the feedback. . .
Xray Nt1 l Xray T3'12 l F104PRO
Chaya is offline   Reply With Quote
Old 10-28-2005, 07:53 AM   #799
JLock's Avatar
No problem, dude. There are many ways to break in a motor, but the way Josh does it, give or take a variation or two, is one of the better one out there.
Texas 5
Old 10-31-2005, 09:34 PM   #800
Sp Racer's Avatar
Let me tell you, those TZ's aren't tuned properly.
I used my T5 last weekend for the first time ever... stripped all the teeth off first gear twice ( I thought it was the mesh first time) , stripped all teeth off second gear once, took teeth off both the rear belt and side belt..
I have never driven anything with so much HP.....nothing came close down the back straight...NS3's, RB V12, JP etc...
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 11-05-2005, 04:08 AM   #801
Trader Rating: 13 (93%+)
Default tuning the tz
hey guys im having some problems tuning the 3 port tz .12
it seams to run fine and quick around 100-115 degrees celcius
what temperature are you guys running at ?
and how long is a tank of fuel lasting ? just wanting to compare my engine setup to some others
thank you
John
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is online now   Reply With Quote
Old 11-05-2005, 08:16 AM   #802
jeff1's Avatar
I usually run with temperature around 115C - 130C, OS engines always run a bit warmer then NovaRossi 130C is still OK
5 minutes and 40 seconds my tank
jeff1 is offline   Reply With Quote
Old 11-06-2005, 07:00 PM   #803
Talking TZ RUNTIME
MY TZ HAS ABOUT 20 TANKS THROUGH IT REALLY CAME TO LIFE AFTER TANK 14 GETTING 6 MINUTES AT 230-250. RUNNIG WITH ALL TYPE OF MODIFIED NOVAS,RB'S,AND THE FAMOUS BREAK A CRANK OR ROD DUO MEGAS AND SIRIOS. ALL I SAY AT THE STRAIGHTAWAY IS SEEEYA!THIS F__KING MOTOR IS BADASS ALSO SAME PLUG SINCE TANK 7 IDLES LIKE A DREAM.
GFIGUEROA is offline   Reply With Quote
Old 11-07-2005, 11:28 AM   #804
Good.....
I just ordered mine and hopefully it will arrive this friday.
It is the fisrt TZR in my city where everyone is runnig mod JPīs, Sirios and Megas.
Letīs see what this little japanese is able to do!!
Nitroblood is offline   Reply With Quote
Old 11-07-2005, 04:23 PM   #805
JLock's Avatar
Just got through running another race weekend on my newly broken-in OS 12tz in my Mugen MTX-3. At my local club track, the temperature never went above 200F degrees and I had more than enough power to catch one guy that was running a Novarossi NS-5. This was at my local club track that is 100 x 120 with a lot of twists and turn (set up more for electric cars than nitro cars). Most of the days runs, the engines temps stayed between 160F to 190F degrees. I will be getting another one for my Tamiya TG10-mk.2 very soon. It is one bad a** motor for sure.
Texas 5
Old 11-07-2005, 04:43 PM   #806
Team-RTR's Avatar
hey guys im just in the middle of running in a brand spankin ZAC project OS TZ 3P. gettin it ready for a big race this weekend, will report how it goes.
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 11-07-2005, 04:45 PM   #807
Default zac tz
hey todd take some pics of the internals
Old 11-07-2005, 06:55 PM   #808
Default MODIFYING TZ
HEY ANYONE SEEN A MODED TZ RUN YET ?
Ahhh the smell of nitro in the morning!
Brooklyn Hobbies Team Driver
[url]www.brooklynhobbies.com[/url]
Team Trinity
[url]www.teamtrinity.com[/url]
Gary Figueroa
Old 11-07-2005, 06:57 PM   #809
ill be racing saturday againts team-rtr ill compare my standard tz to his zac tz
i had a drag race with a max power modified on saturday and was pretty close me being in front, same car kyosho rrr and same gearing
Old 11-07-2005, 07:00 PM   #810
I HAVE 3 MODED NOVA ROSSIS THAT I DID 2 MYSELF THEY ARE SICK! MY TZ CAN ALMOST HANG WITH THEM IF I WORK THE CRANK AND SLEEVE MOTOR SHOULD BE INSANE!
Team Trinity
Gary Figueroa
