Old 06-05-2005, 09:36 AM   #316
ATOMIC's Avatar
Anyone who is interested can send a "NEW" OS12TZ engine to EB MODS and he will mod it identical to the way he did mine for the Texas Biggie. This thing was just flat out amazing , we are talking 1/8 scale speeds. Insteed of the normal $120.00 he will do it for $80.00 , this includes the shipping back to you . The engine must be an OS12TZ and you mst mention my name . (Ron Atomic) His web site is www.ebmods.com
ATOMIC is offline   Reply With Quote
Old 06-05-2005, 04:46 PM   #317
caggers's Avatar
I just want to know if i can use novarossi plugs, i think i will have a problem getting OS turbo plugs as my 2 lhs dont have them.
caggers is offline   Reply With Quote
Old 06-05-2005, 07:37 PM   #318
Darth Vader's Avatar
Originally Posted by Darth Vader
OK, here's my initial impression of the TZ.
I got the 5-port model with slide carb. Fitted on my S710.
Commenced run in yesterday.
Before I installed it, I took it apart to check the internals for any dirt, debris, etc. Looks good. Now I regret not taking pics.
Run in,
1st tank, ran really rich at WOT to flush out whatever foreign items left in the engine. Temp at around 70+C.
2nd tank, leaned a bit and ran around the track straight at mostly WOT. Temp in the 80+C range. Stopped after 1/2 tank let engine cool and commenced running.
Same for the 3rd tank. Leaned slightly, about 15~20degrees HSN.
4th tank, ran full tank around the track, like normal driving, leaned enough for 2nd speed to kick in but still very rich. At this point, HSN is about 1 1/2 to 1 3/4 turns out from fully closed. Didn't touch the other 2 needles so far.
5th tank, leaned to 1 1/2 turns out. Running very rich but able to kick in 2nd speed without problem. Down the straight, , already as fast as my 12 TR. Infield still sluggish because still very rich.
Engine temp, still around 90C... Exhaust manifold temp at 120C range.
FYI, I ran it at night. Ambient temp around 25degrees.
P/S still very tight. Sometimes, still jammed at TDC when I try to start from cold.
Will continue run in this weekend.
Gonna bring engine temp to around 100+C from 6th tank onwards to get proper heat cycling.
I welcome any comments, tips ,etc...
Cheers...
Completed my run in last weekend. Finally...
From the 7th~8th tank onward, it became difficult to run with very rich settings. So, had to lean the bugger. At around the 10th tank, the temp was at around 120C and that was in the middle of a hot Malaysian day. With the same setting, it dropped to around 105C in the evening, when it's cooler.
Didn't have the time to sort out my gearing and 2-speed yet. I think the 2 speed is opening too early. It was set for my previous engine, the TR.
The engine is fast. At least on par with the Novas.
Darth Vader is offline   Reply With Quote
Old 06-05-2005, 09:06 PM   #319
Z00M's Avatar
Trader Rating: 15 (100%+)
Originally Posted by caggers
Can i use any other brand turbo plug on the TZ or does it only take OS ones?
I use the Novarossi C6TGF plugs without any problems over here in the west. The original plug that came with the motor died pretty quickly but you would expect that during break in.
The Novarossi plugs last really well in this engine.
Cheers,
Mike.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 06-05-2005, 09:34 PM   #320
Trader Rating: 44 (100%+)
are you guys running the 3-port or 5-port TZ?
wyl03 is offline   Reply With Quote
Old 06-06-2005, 12:22 AM   #321
Cheers,
Mike.
My engine actually came with a faulty plug.
I used an old plug for running in and then changed to the one thact came with the engine. Keeps stalling when I remove the glow igniter. Changed to another plug and was OK.
Old 06-06-2005, 12:23 AM   #322
5-port...
Old 06-06-2005, 01:46 AM   #323
finchy's Avatar
Thumbs up
Witnessed first hand this little beast at a club meet at the next worlds track yesterday. The motor had good power right around the course. Just have to see the durability side of things now. But it's pretty impressive motor good job OS. :
Inf1nity IF1
OS Speed
KO PRO PO
Runnertime
Hudy
finchy is offline   Reply With Quote
Old 06-06-2005, 10:13 AM   #324
yodace's Avatar
R/C Tech Charter Subscriber
Which engine do guys recommend for offroad racing the 3 or 5 port?
yodace is offline   Reply With Quote
Old 06-06-2005, 10:29 AM   #325
JLock's Avatar
Probably the 3-port for short tracks and the 5-port for the larger tracks where you may need the power if there is a long straightaway and long jumps. Just my opinion.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 06-06-2005, 12:57 PM   #326
3 port would be easier to drive and better low end, if power is what you want then it would be 5 port.
howardjones is offline   Reply With Quote
Old 06-06-2005, 05:27 PM   #327
Z00M's Avatar
I think you'll find a few people will start bolting in these new TZ's. I have run mine now for the equivalent of 7 race meetings so far and it doesn't even look like slowing yet. Very minimal wear on the rod, maybe the bearings could use replacing shortly, but apart from that I have no issues at all. Still has very good compression, even when hot.
The only hint or tip I can suggest is that the carb retaining bolt should be tightened as per the direction in the manual, otherwise the clear spacer around the base of the carb does crack. I know, I didn't read the book
XRAY XB4
Old 06-06-2005, 05:27 PM   #328
how about mileage?
would there be significant differences in fuel consumption between a 3 vs 5-port?
ZOOM - are u running the 3 port in WA?
Old 06-07-2005, 01:34 AM   #329
finchy's Avatar
Zoom your quite right, for the money you can't go passed these engines. I run the VZR ver II in my MRX3 and will it's not quite the missle the Nova based engines are the power band seems to be more linear. This something I really notice with the 12TZ on the weekend and how cool they run.
Inf1nity IF1
OS Speed
KO PRO PO
Runnertime
Hudy
Old 06-08-2005, 06:46 PM   #330
I just got my V1RRR WCE put together. Now, the next task for me is to break in the engine. I have a TZ 5 ports. what would be a good break-in process? Would it be worthwhile to buy a break-in stand? What I have in mind is a cheap one(still expensive), like Nanda engine break in stand. Any suggestions? thx.
silverM3 is offline   Reply With Quote
