Old 05-16-2005, 12:32 AM   #241
finchy's Avatar
Has anyone had and problems with the main bearing in the TZ series. Just a question? I know in the 21VZ II the rear bearing can be susspect after a few litres after break in.
Inf1nity IF1
OS Speed
KO PRO PO
Runnertime
Hudy
finchy is offline   Reply With Quote
Old 05-16-2005, 12:42 AM   #242
Z00M's Avatar
Trader Rating: 15 (100%+)
I'm running the first one here in WA and after 3 litres it hasn't shown any sign of any problem yet. I'll be sure to post if I experience any problems.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 05-16-2005, 05:22 AM   #243
caggers's Avatar
Whats the top end like with the TZ 3-port. A mate told me it lacks punch down the strait, but he is biased to Nova so
caggers is offline   Reply With Quote
Old 05-16-2005, 07:32 AM   #244
Trader Rating: 13 (93%+)
Default break in so tight!
for those of you that have the tz engine
how did you get enough heat into the engine for the piston to expand ?
i cant get this engine to kick over it is so bloody tight!!
mrgsr is offline   Reply With Quote
Old 05-16-2005, 07:47 AM   #245
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
find your self a heat gun or a hair dryer and heat up the block to heat it up as much as possible.
I've used the wife's hair dryer for this in the past and if your not in a rush it works takes a few min to get it up to temp.
Had a buddy who couldn't wait the 3 - 5 min and used a small butane torch with a heat gun type attachment to heat up his block worked good but killed most of his butane charge, that and you have to be very careful with it, blasted thing gets friggin hot.
_______________________________________________________________________
Inferno GT Hyper 21 8 Port Ipanema Tires
Spektrum DX3R
Team CFX Racing, RCNB Race Team, CFX Paintworks.com
regg151 is offline   Reply With Quote
Old 05-16-2005, 07:50 AM   #246
thanks heaps
also are the stock needle settings a good start for break in ?
im going to break in the engine with 1 tank at idle and then the WOT method
what do you guys this about that ?
Old 05-16-2005, 07:51 AM   #247
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: break in so tight!
loosen up the glow plug and turn it over then slowly tighten it up.
Old 05-16-2005, 08:02 AM   #248
regg151's Avatar
Me personally I like the heat cycle method myself. IMO it seems to keep the pinch longer and produce more power.
but I haven't done any scientific comparison tests
Spektrum DX3R
Old 05-16-2005, 08:02 AM   #249
Regional Moderator
daniz24's Avatar
The engine is absolutely screaming, but the speed is normal and nothing special. I guess i just fooled by my own ears
daniz24 is offline   Reply With Quote
Old 05-16-2005, 08:08 AM   #250
Wats the heat cycle method if you dont mind me asking ?
thank you
Old 05-16-2005, 08:28 AM   #251
regg151's Avatar
there are several variations but I do it this way.
heat up the block to at least 150 f
start engine in car and drive it to get the temps up to a min of 210. not driving it hard but going thru the full range for about 3 mins
stop the engine via the flywheel and make sure the piston is at the bottom of the stroke and let cool for 5 - 10 min.
ReHeat the block to 150 f and drive again for about 3 min going thru the full rpm range.
stop via flywheel let cool with pistom at bottom of stroke
I repeat this procedure for 3 full tanks (75cc) then I start to tune for power as normal. I've done this to 4 engines so far and not had a single problem yet. I have a picco .26 that's about to hit the 14 gallon mark that I used this method on and it still has pleanty of compresion left. I did 2 .12 and they both scream they both have just over 2 gallons on them and the fourth one is still in the process of breaking in
Spektrum DX3R
Old 05-16-2005, 09:15 AM   #252
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Zoom, I'm not talking about other engines here.
Anyway, along with the break in method, mark where your flywheel reaches TDC- it helps during the break in. My LHS should be getting them later on so my friend can get one in his NTC3 so we can run together.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 05-16-2005, 01:44 PM   #253
Default Great engine!!!!
Ran 12 tz for the first time this weekend.Was easy to tune and the performance was great.Good low to mid.Topend was super.
When the car would shift to second it was goodbye.All types of
mod engines in field.
athrun is offline   Reply With Quote
Old 05-16-2005, 02:19 PM   #254
uaerc's Avatar
My 6 OS TZ's arrived in just 4 days from Champ.... they are great...... bit expensive on the shipping and bank charges......but all fades away when u see the engines!!
why 6? well one for each team member of my team. We all got RRR's and K3's and Fantom.....yeah we all just got really involved in Racing !! and Imagine from Jets to Cars...... lol
All RRR's will have the OS TZ in it. Except for me It will be on my FWo5RR.
Just a quick qs. though How does the Skyline Pipe work on this. the fat outlaw......
and the normal OS pipes ?
or do i need to get a turbo pipe ?
Cheers
ZiiZO
uaerc is offline   Reply With Quote
Old 05-16-2005, 03:18 PM   #255
jeffreylin's Avatar
R/C Tech Charter Subscriber
Cheers
ZiiZO
I don't have a TZ but Skyline pipe is the best I know for the FW05RR and I've tried many different pipes.
jeffreylin is offline   Reply With Quote
