Old 01-12-2005, 02:54 PM   #1
j240z's Avatar
Default Replacing engine bearings......?
I bought a used engine from ebay...... ....MT12
Anyways I took it apart, cleaned everything up and started putting it back together. It seems there is some play in the bearing.
Is there anyway to tell if the bearings are bad before I put everything back together?
Also, how hard is it to replace these bearings?
Does anyone know if these bearings are intercjangable with novarossi RS12 series engines?
j240z is offline   Reply With Quote
Old 01-13-2005, 02:13 PM   #2
shiston's Avatar
The main thing is to get the bearing sizes, I'm sure u can easily get replacement bearing.
Removing the bearings may be tricky, I've never done it but I believe you would have to heat up the engine block on a stove first and then tap them out.
Hang around......we'll talk some more
shiston is offline   Reply With Quote
Old 01-18-2005, 06:01 PM   #3
Bud
This is a good artical to read if you're rebuilding your nitro engine. Page 3 has the info on removing bearings.
http://www.rcnitro.com/rn/articles/ht_rebuild.asp
Bud is offline   Reply With Quote
Old 01-18-2005, 08:12 PM   #4
j240z's Avatar
Awesome thanks!
Procedures for removing & replacing rear engine bearing .21 picco. Loveless Nitro On-Road 7 05-02-2008 10:07 AM
Replacing Engine's rear bearings? MetalShield Nitro Off-Road 7 02-19-2008 01:57 AM
Replacing Engine's rear bearings? MetalShield Nitro Off-Road 2 02-18-2008 08:08 PM
Replacing Engine's rear bearings MetalShield Nitro Off-Road 0 02-18-2008 02:24 PM
REPLACING BEARINGS casimirsa Onroad Nitro Engine Zone 12 05-20-2007 09:36 PM
