Old 01-07-2005, 08:15 PM   #1
Send a message via AIM to t-maxxfantom Send a message via Yahoo to t-maxxfantom
Default darn it agian i need quick help
ok i haev gotten my hyper .21 8 port through 2 tanks of fuel now with no problems in between
so i figure ok put fuel in it and drive well now it dont want to start
ok what it does is if u pull once it goes rraaeerrrr it just like a quick little start so i wait 5 more secs it does the same thing every five seconds u pull
ok if i pull non stop it does nothing i just pull my arm out
i tried richening it up een trying to heat it with a heat gun and it pulls just the same and does teh same thing as without a heat gun
if i lean it it does nothing at all really
i have all my needles to break in settings right now because i turned them back to get help
i would love to get this thing running before late tomorrow when the snow is gone
i am not tryign to start it in the cold btw i am starting it in a warm house on the back porch which is heated
t-maxxfantom is offline   Reply With Quote
Old 01-07-2005, 09:16 PM   #2
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
I had the same problem with a Hyper 7 and mr .12 it was a little cold here only in the 40's all I did was let the glow driver sit a little longer than 5 sec and heat the engine with a hair dryer. i think the fuel is to cold and won't fire fast try it it might help
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-07-2005, 09:40 PM   #3
well its 70 on the back porch and the fuel should be fine
i dont haev to heat the motor i tried that and it dont help me now
it did for the first tank but not now
Old 01-08-2005, 09:09 AM   #4
help please
Old 01-08-2005, 08:33 PM   #5
20 SMOKE's Avatar
go back to your first settings put a new glow plug in it, it might be bad and charge the glow driver
Jamie W
Old 01-08-2005, 10:28 PM   #6
ok i did go back to the new settings before u all could help and btw it worked all the stuff was charged and the plug was brand new
but we gotta new problem the one way seems like its skipping when its inside the motor when it ake it outs the motor its fine
Old 01-09-2005, 09:57 AM   #7
come on people help a brother out
the one-way looks fine the shaft is fine
Old 01-09-2005, 10:09 AM   #8
also can u tell me if it is normal for a pullstart to go out this quickly mines been rebuilt numerous times
and the motor has only had a bout 3 1/2 tanks on it
Old 01-09-2005, 10:21 AM   #9
20 SMOKE's Avatar
some time they do can you use a starter box
Jamie W
Old 01-09-2005, 10:31 AM   #10
no i cannot use a starter box it is in a savage ss
Old 01-09-2005, 10:34 AM   #11
20 SMOKE's Avatar
clean the pull start and shaft of the motor and one drop of one way lube on it if that doesn't work put a new oull start on it
Jamie W
Old 01-09-2005, 10:36 AM   #12
ok i will try that but they are already clean i will just have ot clean some more
also i wanted help because i have no money to buy a new pullstart
Old 01-10-2005, 09:04 PM   #13
spyspeed's Avatar
It seem Your engine is rich, Try this setting:
-HSN 3 turns out from closed
-LSN 3/4 turn out from flush with throtle body
-Midrange Flush
Mine was pulling wheelie with this setting...
(Slipper clutch 1/8 turn out,OS A5 plug,Gammalube 25%)
As for the one way You can clean it with gasoline then spray with WD40
Hope this help...
spyspeed is offline   Reply With Quote
WHY IS THE SITE SO DARN SLOW? STLNLST Electric On-Road 38 02-01-2008 01:31 AM
DARN NEAR TOTAL SELL OUT!! DFroyd R/C Items: For Sale/Trade 4 06-03-2007 09:40 AM
darn screws won't budge rcburner Nitro On-Road 6 05-09-2004 10:52 PM
'Bout darn time... AZ_Ron Electric On-Road 14 09-29-2003 04:13 PM
help please quick! GTMilenko Electric On-Road 2 07-10-2003 04:41 AM
