Old 08-23-2010, 08:25 PM   #1306
FaanP's Avatar
Thanks for all the replies .... I now feel a bit more comfortable buying the motor. Can you guys give me some direction on where to get one - I'm struggling to get some answers out of the online hobby store where I wanted to buy it - thus I think I must look for a different supplier.
FaanP is offline   Reply With Quote
Old 09-01-2010, 01:27 AM   #1307
keavze's Avatar
Default head shims for DSIII
anyone knows what's the head shims to have for the DSIII zx21 using 25%?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 09-06-2010, 08:16 AM   #1308
Hi,
there are so much factors affecting head clearance, but 0.5 should be a good starting point.
OliverT is offline   Reply With Quote
Old 09-06-2010, 11:51 AM   #1309
M7H
M7H's Avatar
Originally Posted by OliverT View Post
Hi,
Don't mix both...
to get 0.5mm head clearance, you in general have to put in 0.3mm of head shims.... But I have seen head buttons of 0.2mm and of 0.3mm (distance between piston and head button when put into the liner with no head shims)
The best is to measure it, don't do this with a brand new engine, but you can do it after the first gallon. (to much pinch when they are new)
Remove the glow plug, turn the flywheel and put the piston at TDC, only then unscrew the cooling head and head button (otherwise you will push the liner up)
Now take your caliper and measure the distance between top of piston and top of liner. also measure the distance the head button goes into the liner (remove all shims!) the difference is the head clearance the engine has without shims (0.2/0.3mm)...
Don't forget to turn the flywheel, to get the piston out of TDC!
Serpent
M7H is offline   Reply With Quote
Old 09-06-2010, 12:19 PM   #1310
Roelof's Avatar
Send a message via ICQ to Roelof
Just use a piece of solder.
Bend it in an L-shape, put it through the plughole, turn the flywheel arround so the piece of solder will be squeezed between head and piston.
Messure the squeezed solder, that is the head clearance.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 09-06-2010, 06:29 PM   #1311
keavze's Avatar
so am i right to say that for .21 engines, i would need 0.5mm of actual head clearance to use 25% at sea-level with airtemp 80-90F and humidity 70-80%?
Old 09-07-2010, 08:31 AM   #1312
M7H
M7H's Avatar
That should be right yes, maybe 0.1mm more and run a richer setting at that temp/humidity.....
Serpent
Old 09-07-2010, 08:42 AM   #1313
Roelof's Avatar
Different brands have a different headclearance so maybe it is better to say Picco .21 engines have a clearance of 0.5mm ?
Old 09-07-2010, 08:59 AM   #1314
afm
afm's Avatar
From my experience:
Minimum effective clearance (piston to head) on any .12 engine is 0.4mm
Maximum effective clearance is 0.8mm
Minimum effective clearance for any.21-.32 engine 0.50-0.55mm
Maximum effective clearance 1.1-1.3mm
Rule I've always gone by, on the safe side is:
0.60 on a .21 running 25 - 30% nitro and a #7 plug
0.50 on a .12 running 16 - 20% and a #6 plug
Relative humidity on ambient. The more humidity (more water on the air), more chamber is needed. I'll add one 0.10mm shim for each 20% it raises over 70%. I use a small weather station for measuring temp, barometric pressure and relative humidity on the track. It is a great tool to know the quality of the air your engine is breathing.
Height over sea level. As you go higher, there is less oxygen on the air, so you have to reduce space on combustion chamber (more compression). The more you approach sea level, you need to make more space for the additional Oxygen present in the air.
AFM
afm is offline   Reply With Quote
Old 09-07-2010, 05:03 PM   #1315
Please read AFM's post carefully. The clearance is to be measured as stated piston to head. Not just shim thickness. Big difference when it comes down to thousandths of inch or hundredth's of a MM. The quickest way to check the clearance from the head to the piston is to crush some solder and measure the part that was crushed. The most accurate is to measure all and then do the math I have found no difference if the solder technique is done correctly.
xspower is offline   Reply With Quote
Old 09-12-2010, 08:23 AM   #1316
keavze's Avatar
Default zx21 DSII vs DSIII
hi guys,
anyone knows the difference in engine characteristics/performance between the zx21 DS3 and DS4? or rather between the .21 picco evo3 and evo4?
the 4 has better topend but the 3 has better lowend?
p.s. forget the title...typo error
Old 09-12-2010, 06:49 PM   #1317
The crankcases of the Mega's are completely different in volume to the Picco case. You should have some more top end with the Mega's as the case volume is slightly higher. The 4's for both have a under head that is fashioned after the Nova with the o ring support.
Old 09-12-2010, 10:56 PM   #1318
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Still doing engines Jerry?
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 09-13-2010, 05:56 PM   #1319
Yes Scott.
WTB: Mega Picco Header and pipe .12 rcfoolz R/C Items: Wanted to Buy 0 10-07-2007 07:46 PM
FS: Mega Picco .21 DSII with spares mrgsr R/C Items: For Sale/Trade 3 12-02-2006 03:09 PM
KYOSHO RRR WCE,Mega picco Carlsen Modifeid GMartinez R/C Items: For Sale/Trade 15 02-08-2006 07:40 PM
^^^ NIB MEGA PICCO ZX12 VERY CHEAP AND USED MEGA PICCO PIPE ^^^ Riketsu R/C Items: For Sale/Trade 2 12-09-2005 03:54 PM
Mega-Picco ZX-12 Pandora's Box Malaysian R/C Racers 52 04-08-2005 01:37 AM
