Old 06-25-2007, 07:24 PM   #1231
lil-bump's Avatar
Trader Rating: 83 (100%+)
Default Mega 2607 pipe & header
I recently mounted this pipe(Mega-2607) to my MTX-4. But the shape of the header positions my pipe too far away from the chassis. My pipe and springs take a beating being so far away from the chassis. Is there a different syle header that keeps the pipe closer to the chassis.
lil-bump is offline   Reply With Quote
Old 07-18-2007, 08:31 PM   #1232
jeff1's Avatar
does anyone knows part number of o-ring that goes inside crankcase of ZX12? Exploded view only shows the one that fit on carb body
thanks
jeff1 is offline   Reply With Quote
Old 07-20-2007, 03:17 AM   #1233
Hi - can anyone help!?!? Re: ZX21 DSI
I have a ZX21 DSI - i bought it second hand, and after about 5 tanks, the conrod went. had to replace the piston and sleeve too - and on the new engine have just run it in. i REALLY dont want this one to go so quick this time as i cant keep affording to replace the whole lot!! SO.... could anyone out there who has had experience with this engine tell me what the ideal running temp range is - as i have just bought a temp gun to try and prevent me letting it overheat - but it aint much good cause i cant find what the running temp should be of this engine anywhere!!
Thanks alot!!!!
leonmatthew is offline   Reply With Quote
Old 07-20-2007, 04:10 AM   #1234
M7H
M7H's Avatar
Leon, the DSI is know for it's problems with the conrod.
Keep the engine on the rich side on the LSN, and try to run it not hotter then 100-110C /210-230F
Replace the conrod every 3 liters of fuel.....
Do you know how many liters or gallons of fuel allready went through the engine? because the crankshaft wears to and might come to a point where changing the conrod isn't enough anymore....
M7H is offline   Reply With Quote
Old 07-20-2007, 05:05 AM   #1235
quietstorm76's Avatar
I agree with M7H. I had the same thing happen to me. For break-in open HSN 6 turns from closed. Make sure you use Picco plugs only or you will be chasing tunning issues. Keep the temp in the 190-200 range for break-in.
quietstorm76 is offline   Reply With Quote
Old 07-20-2007, 07:52 AM   #1236
thanks!!
Old 07-20-2007, 01:25 PM   #1237
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Conrods
HEy just so you know the IDM conrods fit in the Mega zx12 perfect.
impalabob64 is offline   Reply With Quote
Old 07-20-2007, 02:02 PM   #1238
Team Kamikaze's Avatar
So does the Mega con-rod M12-15 T3 #202182(for the DS II)
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-06-2007, 12:42 PM   #1239
Xray prince's Avatar
Default MEGA/REDDOT
Fellas I have a MEGA ZX12 tht isnot running anymore and I purchased a REDDOT today.....Do any of u kno if I would b able to use the lower profile heatsink from the MEGA on the REDDOT? being tht there both PICCO thanks!
Xray prince is offline   Reply With Quote
Old 08-07-2007, 08:22 AM   #1240
roadrage's Avatar
Trader Rating: 14 (100%+)
i use the option tall mega head on mine and is fine,but with less fins on the standard mega head there might be a great temp difference im guessing.
Austin Wolfe
Serpent America-Trinity/Revtech-www.ActivRC.com
roadrage is offline   Reply With Quote
Old 08-07-2007, 08:41 PM   #1241
thanks......If heat becomes a prob I guess I'll hav to go bac to the stock Cooling head
Old 08-15-2007, 08:32 PM   #1242
http://www.serpent.com/product/201015/
http://www.serpent.com/product/201509/
Luke W is offline   Reply With Quote
Old 08-15-2007, 08:58 PM   #1243
roadrage's Avatar
wow. from what i here and try to order.serpents done with the mega line. i wonder how that is with this new motor if it will be avalible or not
Austin Wolfe
Old 08-16-2007, 07:56 AM   #1244
M7H
M7H's Avatar
Because Picco is earning enough money from OFNA, the engine's produced for Serpent (Mega), Ielasi (IDM), and Solaroli, are hard to get, and probably not there 1st priority.....
Hopefully in the near future Picco will step up the process, and deliver more engines to these 3 clients.
Certainly because 2 other engine brands (will not mention names here ) are having issue's at the moment, it is a good time to have these Picco based engines on stock in the LHS......
Old 09-04-2007, 07:06 AM   #1245
verlassen's Avatar
Default picco crankcase for zx21 sport ?
is any of the picco crankcase can fit the zx21 sport ?
a friend of mine had just broke the conrod during practice and the rod went straight thru the crankcase. Anybody tried swaping the zx21 sport crankcase with a picco one ?
verlassen is offline   Reply With Quote
WTB: Mega Picco Header and pipe .12 rcfoolz R/C Items: Wanted to Buy 0 10-07-2007 07:46 PM
FS: Mega Picco .21 DSII with spares mrgsr R/C Items: For Sale/Trade 3 12-02-2006 03:09 PM
KYOSHO RRR WCE,Mega picco Carlsen Modifeid GMartinez R/C Items: For Sale/Trade 15 02-08-2006 07:40 PM
^^^ NIB MEGA PICCO ZX12 VERY CHEAP AND USED MEGA PICCO PIPE ^^^ Riketsu R/C Items: For Sale/Trade 2 12-09-2005 03:54 PM
Mega-Picco ZX-12 Pandora's Box Malaysian R/C Racers 52 04-08-2005 01:37 AM
