MEGA (by Picco) thread
#1202
The MEga MF also uses the oooooooooooooooooooooooooooooooooooooolder carb from NovaMega..........
and the ceramic bearing has 11 spheres while the current 11,5mm bearings that are being used in the latest Novarossi engines are 9 sphere and they're light gray coloured, very different from the dark colored ceramic bearing we're used to see.........
#1203
Thanks guys. What about performace? They are both supposed to hand tuned by Mr. MF. Also what is considered the better piston, microcast or (BAR) machined?
#1204
Jag, I believe the P/S height is also different. As for performance, I have not seen CNC piston on MF.12 (ceramic or not) runs any slower than microcasted Max SL lines. I like to say the Masmo are faster, but that`s a bit bias.
Furthermore, CNC piston has more advantage on overheating. I mean, when overheating symptom started to occur (and still being run for a while), just rich it back and nothing happened to the piston.
#1205
Would the Max PL3 be a closer match to the MF? They don't look the same but the specs are similar. The SL and MF look like the Plus12 line where as the PL looks like the LL line. I don't get it.
#1206
Hi Jag, I think even microcast, they still need CNC touch for finishing. Not sure about PL line
#1207
Hey Jag...take a look at your email
#1208
I didn't get any email from you yet.
#1209
Originally Posted by jag
What's up Francis?
Jim...I'm sending you a PM. I think I only have sth-arch.com email. Or if you still have my email send me one from your active account. Later.
#1210
mEGA
Hi Guys,
Has anyone tried the new MEGA PICCO ZX12 EDO TUNED version. How is this motor. What for a charestic has this motor. Is it better than JL red dot picco?
thnx
thnx
#1211
Originally Posted by CIMRI
Hi Guys,
thnx
thnx
I have both, the JLR Red Dot and the Picco P1R Evo2 Edo Tuned and both are ballistic.
AFM
#1212
Originally Posted by afm
Where have you seen this engine??? are you sure it is a MEGA?? because I know there is a PICCO P1R Evo2 Edo Tuned, and a just released Evo3 Edo Tuned, and there is a soon to be released MEGA ZX12 DSII Plus, which will be quite similar to the EVO3.
AFM
AFM
EVO 2 was Efra legal.
#1213
mega
AFM
AFM
I saw at Border Rc web site. But now it is not to find. I am sure. It was mega Picco EDO SPECIAL TUNED. I will sen to border a mail and ask why they not more this engine to find is.
thnx
#1214
Originally Posted by stefan
The Picco Evo 3 should be identical to the JLR. It's got the "full turbo" crank now since we have the IFMAR engine rules in Europe now.
No, the JLR doesn't have the full turbo crank yet. It has the straight 7.00mm bore and non protruding turbo scoop (old EFRA rules).
The Picco Evo2 Edo Tuned has the 9.00 to 7.00 mm bore crank and still a non protruding scoop.
The Picco Evo3 will have a 7.5 or 8.00mm straight bore (to be confirmed) and the full protruding scoop. Rest of engine as the JRL or Picco Evo2.
AFM
#1215
Not sure if this has been asked before but I'm hoping someone could answer the question in this thread.
Will the following ZX21 DSII parts fit the original ZX21 Race:
ABC Set 202174 (piston/liner/turbo head)
202170 Conrod
202168 Wrist Pin
202169 Wrist Pin Clips
I still have the first ZX21 and would like to rebuild it. I was sold the wrong piston/sleeve (DSII instead of the ZX21 RACE part 202002) and found out that the hole for the wrist pin is smaller than the original.
Thanks.
202170 Conrod
202168 Wrist Pin
Thanks.
