Old 11-27-2006, 04:32 PM   #1126
quietstorm76's Avatar
Originally Posted by M7H
And, do you have the engine yet?....
I have no bad experience with the engine to share with you.
I have 2 ZX21 DSII engines, 1 brand new, still needs to be broken in, and 1 older one which is 5.5 liters of fuel "old" now, of which I'm going to replace the rod when the new season starts.
Even though these engine don't have a lot of "pinch" when new, the engine still has the same amount of pinch after 5.5 liters as it had after break-in.
Yes I have the engine. I haven't started breakin yet though. Thanks for the feedback. I was just a little gun shy about the motor because I ran a DSI for about 4 races during the summer. Changed the rod after breakin and it snapped the rod a half gallon after that. I've heard that has been corrected with the DSII.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 11-28-2006, 01:17 AM   #1127
M7H
M7H's Avatar
Ok, fair enough......
Good luck with the engine then......
Serpent
M7H is offline   Reply With Quote
Old 11-28-2006, 05:50 AM   #1128
Bundy_Bear's Avatar
Originally Posted by dj apolaro
It sounds to me like your head clerance.
I haven't touched the head shims, i was under the impression in the instructions that they were correct for 16% nitro etc
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 11-28-2006, 02:24 PM   #1129
ek
ek is offline   Reply With Quote
Old 11-28-2006, 02:39 PM   #1130
M7H
M7H's Avatar
When it runs ok the first few minutes, but when heated up properly, starts to bog down, I think your bottom end is to lean.......
Because the composite carb. needs more time to heat up then the engine, people start to tune the engine to fast, first let it heat up properly, then start tunning, not earlier....
Serpent
Old 11-28-2006, 02:39 PM   #1131
Started breaking today and everything went smooth. 7 tanks, no flame outs, #7 plug on 30%. Thing motor is very smooth, not peaky like the DSI. It's still on the rich side but from what I could tell once it starts pulling, it keeps pulling all the way to the top end. I like this motor already.
Primary Weapon: ?
Secondary Weapon: ?
Old 11-28-2006, 02:44 PM   #1132
M7H
M7H's Avatar
Keep the bottom end on the rich side, and you will not have flame out problems, overlean it, the plug will damage and the engine will change into "flame out mode"
Serpent
Old 11-28-2006, 03:01 PM   #1133
ek
Smile
Old 12-01-2006, 07:13 AM   #1134
I use the "Josh Cyrul" methode.......
http://www.cefx.net/tips/nitro/break-in/index.php
With a small change in this procedure, to speed it up a bit.....
- preheat engine with hairdryer
- run the engine full throttle (yes very rich) on the startbox for 3 tanks.
- cool down (15-30 Minutes)
- another 2 tanks full throttle
- close the main needle 1/2 turn
- 1 tank of throttle blipping (3 seconds idle, 3 seconds full throttle, 3 seconds idle,......)
- hit the track with a leaner setting that the car will move, change your clutch to early engagement, otherwise you will burn the clutchshoe.
Now on every tank I lean the engine 1/8 of a turn, until it reaches the perfect mixture....
Should be there after 1 liter of fuel (about 1/3 of a gallon)....
A Mega engine doesn't have this huge pinch like a Nova has, so the stress on the conrod and main bearing is way less......
Changing conrod after break-in therefor is not neccesary in my opinion, I change them every 5 liters or so (1.5 gallon)
(Yes I will now change the conrod in my Mega, but the next time I will drive it will be somewhere in Feb/Mar next year, season is over now.....)
Also RickV from Mugen/Ninja shares this idea.....
http://www.rcjracing.com/e107_plugin...php?content.45
Hi M7H, i just bought a ZX21 DS2 and want to follow ur break in method...
just wondering do u monitor the temp during break in??
do u keep it at certain temp and how do u keep it there??
CK
ck960 is offline   Reply With Quote
Old 12-01-2006, 07:37 AM   #1135
M7H
M7H's Avatar
Hi ck960.....
No, I don't really monitor the temp, because due to the amount of fuel flushing the engine, the temp will not be very high... (somewhere around 70 Celcius or 160F)
I even cover the engine with a towel or something to try to get the temps up a bit (watch out for spinning wheels or gears.... )
I also want to tell you, that according to the Cyrul methode "richening the engine until it flames out and then go back 1/4 turn on the HSN", might not work properly because it then rev's very unstable on full throttle, I choose the riches as possible setting, but so that the engine revs steady......
Serpent
Old 12-01-2006, 07:42 AM   #1136
Thanks for the info... i'll be running it this weekend
Hope everything goes well...
thanks,
CK
Old 12-01-2006, 08:20 AM   #1137
M7H
M7H's Avatar
1 more thing....
The DSII comes with 0.4mm of head clearance (or 0.5)
check the amount of head shims, I run both my DSII's with 0.6mm (1 still needs to be broken in....)
0.4mm gives you more bottom, which is for smaller tracks, 0.5 or 0.6, gives more top end, but a little less bottom....
0.4mm on the tracks I run, might give detonation....
Serpent
Old 12-01-2006, 08:50 AM   #1138
1 more thing....
I'm running .54mm on mine. Medium track and bottom end is enough for me. That .4mm sounds about right out of the box.
Primary Weapon: ?
Secondary Weapon: ?
Old 12-01-2006, 10:32 AM   #1139
1 more thing....
My DSII came with .5mm out of the box. It does give more bottom end power than .6mm clearance. With .6mm and 30% fuel it is a little soft. I've had to work on the clutch and gearing to get it to pull harder out of the turns. I think I might try .55mm the next time out to get that happy medium.
Kendall is offline   Reply With Quote
Old 12-02-2006, 06:25 AM   #1140
1 more thing....
Thanks for the advice, mine comes with 0.5 shim, so i think i'm ok, my local track is not that long, just medium and with tight u turn... maybe will try with 0.4 head shim cos i'm only using 25% nitro... is it adviseable??
thanks
CK
WTB: Mega Picco Header and pipe .12 rcfoolz R/C Items: Wanted to Buy 0 10-07-2007 07:46 PM
FS: Mega Picco .21 DSII with spares mrgsr R/C Items: For Sale/Trade 3 12-02-2006 03:09 PM
KYOSHO RRR WCE,Mega picco Carlsen Modifeid GMartinez R/C Items: For Sale/Trade 15 02-08-2006 07:40 PM
^^^ NIB MEGA PICCO ZX12 VERY CHEAP AND USED MEGA PICCO PIPE ^^^ Riketsu R/C Items: For Sale/Trade 2 12-09-2005 03:54 PM
Mega-Picco ZX-12 Pandora's Box Malaysian R/C Racers 52 04-08-2005 01:37 AM
