Old 09-25-2006, 07:02 PM   #1051
Originally Posted by Kendall
The settings are for the ZX-21 DSII.
Any chance of getting the stock settings for the ZX-12?
James "Nel" Nelson
SpeedWorld Raceway & Hobbies | DesotoRacing.com | R1 Wurks
neltime64 is offline   Reply With Quote
Old 09-25-2006, 07:17 PM   #1052
afm
afm's Avatar
Start around here:
HSN: 4 1/2 turns out
LSN: 5 1/2 turns out
AFM
afm is offline   Reply With Quote
Old 09-25-2006, 09:44 PM   #1053
Originally Posted by afm
Start around here:
AFM
James "Nel" Nelson
Old 09-26-2006, 01:27 AM   #1054
M7H
M7H's Avatar
Originally Posted by mrgsr
m7h.. if i start the engine with the low end that far out it runs very rich, i now have my low end pretty flush with the carb body and it seams ok, but still only going to 85-90degrees Celsius and still rich middle range.
im gonna take it to the lhs the guy there is has been racing nitro for over 20 years his pretty good with tuning.. illlet u know how it goes
With that temp, I think you can lean the top a bit, and after that probably you need to richen the bottom also.....
Serpent
M7H is offline   Reply With Quote
Old 09-27-2006, 10:16 PM   #1055
Trader Rating: 13 (93%+)
Default engine prob solved..
Thanks everyone for your help
The engine ended up having a rich low end. Its now able to idle for more than 30+ seconds and then take off with just a slight rich blurb.
The low end needle actually sits screwed in about 1.5 mm from the carb body.. temps are up in the 100degree range now with the engine making great power.
thanks guys!
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 10-04-2006, 06:33 PM   #1056
Default diameter of carb neck?
hi
does anyone know the diameter of the carb neck on the dsII .21 ?
thanks
Old 10-04-2006, 06:57 PM   #1057
Trader Rating: 17 (100%+)
The DS II .21 , like most engines, comes with different size inserts for the carburetor: 7, 8, & 9.
Clay.
seabass2500 is offline   Reply With Quote
Old 10-04-2006, 07:40 PM   #1058
i meant the neck where it fits in to the engine block
thanks
Old 10-05-2006, 07:48 AM   #1059
duneland's Avatar
I don't remember the measurement, but if you are thinking of using some other carb,,, Sportwerks carbs fit. They are cheaper & work better than the picco carbs. These do NOT fit; Nova, OS, Sirio, Rossi, Cippola, and Force.
duneland is offline   Reply With Quote
Old 10-05-2006, 07:58 AM   #1060
damn i wanted to use the os vz-r .21 carb
has 3 needle adjustment and just seams easier to work with
i might measure the necks and see
i havent ran it on a track yet to see its performance, here we only have 1:8 races 3rd sunday every month so next sunday ill be able to see how it goes
Old 10-05-2006, 08:13 AM   #1061
duneland's Avatar
It has been my experience over the years, that any carb you can cram in there, will work better that the picco carbs!
I think Picco engines are top shelf. Great materials, long lasting, able to withstand a lot of abuse and high performance. But,,, the carbs are designed by the retarded step-nephew! I can see this scene play out in my mind; (CEOs' wife to CEO) "you hire Gesepe to make carb!" "He like carbs." "You no hire Gesepe, you no get any of this!"
Old 10-06-2006, 04:32 AM   #1062
Bundy_Bear's Avatar
Hi
I have just installed a STS carby onto my ZX12 to see if that improves it any. I will let you all know how i go...
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 10-06-2006, 06:24 AM   #1063
duneland's Avatar
I think in the .12 size engines, you can use Nova with Picco too.
There are also a couple of adapters for fitting OS carbs to Nova or Picco.
Old 10-06-2006, 06:50 AM   #1064
jag
jag's Avatar
Originally Posted by Bundy_Bear
Hi
BB
I use an RB carb on my ZX12 and it works great.
jag is offline   Reply With Quote
Old 10-09-2006, 09:01 AM   #1065
duneland's Avatar
I tried a Cippola carb on my .21 over the weekend. I was very pleased with the results. It did require reducing the size of the neck, in order to install it in the Picco block. Not too hard since the neck of the Cippola has an insulating sleave on it. The fiber material cuts nicely on the lathe.
Several advantages with this carb. First, it has all adjustments on the end of the body (opposite of the slide). Far easier to get to the idle speed & low-end adjustments. The flow rates are a closer match to the engines needs than the Sportwerks (and of course the Picco). Still not quite right, but pretty close. The idle is still a little rich when the rest of the low-end adjustment is correct. I will try some different plugs to see if that cures it.
WTB: Mega Picco Header and pipe .12 rcfoolz R/C Items: Wanted to Buy 0 10-07-2007 07:46 PM
FS: Mega Picco .21 DSII with spares mrgsr R/C Items: For Sale/Trade 3 12-02-2006 03:09 PM
KYOSHO RRR WCE,Mega picco Carlsen Modifeid GMartinez R/C Items: For Sale/Trade 15 02-08-2006 07:40 PM
^^^ NIB MEGA PICCO ZX12 VERY CHEAP AND USED MEGA PICCO PIPE ^^^ Riketsu R/C Items: For Sale/Trade 2 12-09-2005 03:54 PM
Mega-Picco ZX-12 Pandora's Box Malaysian R/C Racers 52 04-08-2005 01:37 AM
