Old 09-16-2006, 03:15 AM   #1036
Bundy_Bear's Avatar
Default zx12
has anyone else had issues with the ZX12 Legal leaking excessive oil from around the carby area at all? I am going to seal it up with high temp siliconne sealent, but was just curious?
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 09-18-2006, 12:15 AM   #1037
Trader Rating: 13 (93%+)
Default whats a good low end tune ?
low end tuning
guys i can never get my head around a good low end tune.
provided the engine is warmed up, do you keep leaning the low end bit by bit till it idles for 10-20 seconds then takes off cleanly ?
or do you listen to the sound of the engine and lean it when the revs drop after a few seconds ?
idle tune: once the low end seams steady, do you adjust the idle so that its low enough not to stall ?
thank you
John
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 09-18-2006, 02:32 AM   #1038
Send a message via MSN to Qlone
I do it just by listening to the sound of the engine. After a few seconds full throttle it should drop back to idle immediately, and then run at a constant RPM. If the RPM drops a little bit, that's ok, but not too much. Then I tune the idle adjustment screw to let the idle be as low as possible.
When doing this, the engine takes off with a bit of sputtering, but without cutting out after about 20 to 30 seconds of idle.
Qlone is offline   Reply With Quote
Old 09-18-2006, 04:03 PM   #1039
Warmac's Avatar
Send a message via MSN to Warmac
BB
I have the zx15 outlaw but they both suffer 'generally' from the same problems. Yes i've had that leak and I've sealed it up. It works pretty well now execpt for that exhaust gasket. Not sure what I'm doing wrong there. i've neve had that many busted gaskets with any of my other engines.
Anyway, seal it up, but don't go overboard doing it. In this case a little goes a far way.
Good luck
Warmac is offline   Reply With Quote
Old 09-19-2006, 04:55 AM   #1040
Bundy_Bear's Avatar
Good luck
Warmac:
Thanks for that, i will give it a try... little disappointed you need to do this though
BB
MissMooRC Racing
Old 09-19-2006, 06:12 AM   #1041
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i dont have the problems of the carb leaking ? where is it leaking from ? the boot near the low speed needle. i found this did leak a little when running the engine in, i put this down to rich needle settings. it hasnt been a problem since it has been run in. also there are 2 types of gaskets for them as well. dont know if you know ? but the serpent pipes require the standardised gaskets, novarossi pipes require the non flanged gaskets, looks like a bit of rubber tube cut down to about 6 or 7mm. hope this helps.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-19-2006, 11:03 AM   #1042
Warmac's Avatar
Bundy_Bear: You are welcome.
Pattojnr: It seems to be the luck of the draw. Where I drive, some of the guys have sold their engine, others have just put them down, some have no problem at all, yet another guy hs changed his carb to a rossi carb and seems happy and of course I've sealed mine up.
Old 09-19-2006, 03:47 PM   #1043
Bundy_Bear's Avatar
It looks like it coming from the throat of the carby where is goes into the crank case, but it is hard to be 100% sure as oil is all over the crank case. I have sealed it with high temp sealent and will see if i have any further problems. I am using that flat rubber gasket on the exhaust for my Skyline pipe
BB
MissMooRC Racing
Old 09-22-2006, 11:10 PM   #1044
Default dsII .21 tune q..
hey guys
ive been tuning my engine i just have 1 question, the low end base setting is 2mm out from the carb..i have my top end set and now my low end needle is flush with the carb body pretty much..my top end needle is about 1/4 turn in from flush, any more and the engine hesitates.
If i go richer on the low end the engine has heaps of run on and actually sounds rich. with these settings now its still rich but keeps a steady idle for about 20 seconds and i can take off with a slight burble sound.
does this sound right ? i just wanna compare with some of your engine settings.
thanks heaps
Old 09-24-2006, 03:28 PM   #1045
M7H
M7H's Avatar
Check my post 1 page back....
http://www.rctech.net/forum/showpost...&postcount=992
It's about the same.....
Serpent
M7H is offline   Reply With Quote
Old 09-24-2006, 05:42 PM   #1046
Thanks MH7
are they your current tune settings or the standard settings ? thanks
Old 09-25-2006, 01:36 AM   #1047
M7H
M7H's Avatar
Those are my current settings......
Serpent
Old 09-25-2006, 03:11 PM   #1048
Originally Posted by Paolo M
Hi Mrgsr,
Main needle flush
Low speed needle 2 mm
This is a starter point on the rich side
Paolo
Does these setting apply to the ZX-12?
James "Nel" Nelson
SpeedWorld Raceway & Hobbies | DesotoRacing.com | R1 Wurks
neltime64 is offline   Reply With Quote
Old 09-25-2006, 04:40 PM   #1049
The settings are for the ZX-21 DSII.
Kendall is offline   Reply With Quote
Old 09-25-2006, 05:49 PM   #1050
m7h.. if i start the engine with the low end that far out it runs very rich, i now have my low end pretty flush with the carb body and it seams ok, but still only going to 85-90degrees Celsius and still rich middle range.
im gonna take it to the lhs the guy there is has been racing nitro for over 20 years his pretty good with tuning.. illlet u know how it goes
WTB: Mega Picco Header and pipe .12 rcfoolz R/C Items: Wanted to Buy 0 10-07-2007 07:46 PM
FS: Mega Picco .21 DSII with spares mrgsr R/C Items: For Sale/Trade 3 12-02-2006 03:09 PM
KYOSHO RRR WCE,Mega picco Carlsen Modifeid GMartinez R/C Items: For Sale/Trade 15 02-08-2006 07:40 PM
^^^ NIB MEGA PICCO ZX12 VERY CHEAP AND USED MEGA PICCO PIPE ^^^ Riketsu R/C Items: For Sale/Trade 2 12-09-2005 03:54 PM
Mega-Picco ZX-12 Pandora's Box Malaysian R/C Racers 52 04-08-2005 01:37 AM
