Old 08-29-2006, 03:29 AM   #1006
Send a message via MSN to PMSorber
Originally Posted by mrgsr
how would the dsII .21 worek with a novarossi efra pipe ?
Last weekend we drove our JP-R03 (modified) with a restrictor manifold and a 2031 exhaust. At the same time om of the teamdrivers of Serpent was testing his DS2 with this new novarossi pipe, I was impressed!
The top of the DS2 was equal or even higher than the R03 ...
I dont know the fuelconsuption on the DS2 with this pipe.
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 08-29-2006, 05:30 AM   #1007
M7H
M7H's Avatar
Pieter, this was Jordy I guess?....
He also drove the pipe during the last race at the AMCA track....
So you are impressed by the performance of the DSII, time to switch, or not?......
If I see the maintenance you do on your JP's, I think it will be a lot more affordable for you......
I will run my DSII also coming weekend, weather depending, I will not be there Saturday, because of other obligations, but I will be there probably Friday.....
Serpent
M7H is offline   Reply With Quote
Old 08-29-2006, 06:21 AM   #1008
Fsturbo15's Avatar
Send a message via AIM to Fsturbo15
If I was to purchase an engine now, it would be this one.
It seems overall better than the Ninja and is even cheaper.
The Ninja just doesn't seem to have that punch and this one seems to scream on the long straights.
The only thing i'm worried about is the reliability factor, the Ninja IMO has a better finish and less chance of exploded as long as you shim right.
From what I hear you need to add a certain ammount of shims for 30% with the Ninja or you're risking it.
Fsturbo15 is offline   Reply With Quote
Old 08-29-2006, 06:30 AM   #1009
Where is the ZX12 DS2 available online and what pipe is recommended with this engine?? Also, do you guys know if this is the same as the LRP Team Spec 3???
Rody is offline   Reply With Quote
Old 08-29-2006, 06:40 AM   #1010
No was'nt Jordy. Maintenance does not cost a lot, it only costs time and should be done on every engine, even Mega
@ConSult Trading
Old 08-29-2006, 06:41 AM   #1011
Fsturbo15's Avatar
Lee Muse posted above that he has them in stock.
www.Gasrccar.com
Great guy to deal with.
He even beats the price of ace-hobbies by $319 to $339!
You cant go wrong with the pipe that the Powerpack gives you...
Old 08-29-2006, 05:46 PM   #1012
Trader Rating: 44 (100%+)
www.Gasrccar.com
rody was looking for the .12 size DSII ...
rody - is there a lrp team spec3 out already???
YOKObori MOkei
wyl03 is offline   Reply With Quote
Old 09-01-2006, 09:23 PM   #1013
royfan33's Avatar
Is the engine that comes in the 201005 Powerpack the same ZX that has gotten the good reviews on here? Sorry for my ignorance, but I can't tell from the limited pics I find on the e-tailers sites. I've found one for $199 and it seems like a good deal...
royfan33 is offline   Reply With Quote
Old 09-05-2006, 09:10 AM   #1014
acutts's Avatar
Help ordering motor and unsure what to go for.
ZX-12 DSII
Mega MF-12 3P MASMO
The Masmo is a bit more expensive but cost not really a prob ... just want to know what would be the better motor.
acutts is offline   Reply With Quote
Old 09-05-2006, 06:03 PM   #1015
where can u get the ZX-12 DSII from?
YOKObori MOkei
Old 09-06-2006, 06:52 AM   #1016
Bundy_Bear's Avatar
Hi
I have just installed my ZX.12 into my G4S i bought from RaceDay Hobbies in the US... I am very pleased with the quality of this engine for it's price, can't wait until i hit the track with it. Certainly not as super tight as the STS i have had in the past
Is the ZX.12 there current model, or has it been superseeded by a new model?
Thanks,
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 09-09-2006, 09:52 PM   #1017
Bundy_Bear's Avatar
Hi
I started to run in my ZX.12 today... have put three tanks through it already, but it appears to be leaking from somewere. I need to have a closer look, but it appears to be from the carby. I know all engines leak a little, normally from the front bearing etc... I am worried about getting oil onto the brake disc on the G4S an loosing my belovered brakes
Hope someone can assist me with this soon.
Thanks,
BB
MissMooRC Racing
Old 09-10-2006, 07:30 AM   #1018
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Hey Bundy, i also am running the Zx12 in the G4S. if its leaking from the carby area ? there are the 2 collets that hold the carby in place. they have O rings on them to seal. make sure they are on or if you havent pinched the orings while putting the carby on. also i would suggest changing the gearing and the clutch spring . i have tried the 18/52 first gear with the new 1.8 black clutch spring. i ran the ZX12 in the mongoose before and it lacked bottom end. making these changes braught the engine to life, totally awesome. try 1mm spring tention gap on the clutch spring.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-10-2006, 08:56 PM   #1019
Trader Rating: 17 (100%+)
I bought the DS-II .21 when it came available a few months ago. It ran well but I had the conrod break on me today... chewed up the internals pretty good. So now I have to buy a new motor.
I liked it when it was running, and nice at the price. I want to buy another one but it is hard when the last one died so quickly. I know that is abnormal but still.
seabass2500 is offline   Reply With Quote
Old 09-10-2006, 09:12 PM   #1020
Bundy_Bear's Avatar
PattoJnr:
I have reseated the carby in the crank case just in case i didn't get down far enough. All the orings look good, will have to wait and see what happens tomorrow now for the practice session...
During my brief run yesterday, i didn't notice any lack of punch off the mark, but the clutch is very aggresive
Will keep you all posted
BB
MissMooRC Racing
WTB: Mega Picco Header and pipe .12 rcfoolz R/C Items: Wanted to Buy 0 10-07-2007 07:46 PM
FS: Mega Picco .21 DSII with spares mrgsr R/C Items: For Sale/Trade 3 12-02-2006 03:09 PM
KYOSHO RRR WCE,Mega picco Carlsen Modifeid GMartinez R/C Items: For Sale/Trade 15 02-08-2006 07:40 PM
^^^ NIB MEGA PICCO ZX12 VERY CHEAP AND USED MEGA PICCO PIPE ^^^ Riketsu R/C Items: For Sale/Trade 2 12-09-2005 03:54 PM
Mega-Picco ZX-12 Pandora's Box Malaysian R/C Racers 52 04-08-2005 01:37 AM
