Old 08-10-2006, 04:08 PM   #976
M7H
M7H's Avatar
Originally Posted by Rookie Solara
what is the typical plugs that ppl commonly use on MEGA ZX-21...? #6 or #7 cause I would like to stock some of those........
I only use the #200161 => turbo 6 cold
and the #200171 => turbo 7 cold
I always try to use the 7, but in case of higher temperatures, which need richer engine settings, which then might give flame-out problems, I will put in the 6.....
You can also use the 7 hot for that purpose.....
I think you should order both the 7 cold and hot types........
Serpent
M7H is offline   Reply With Quote
Old 08-11-2006, 03:37 AM   #977
Bundy_Bear's Avatar
Can you explain to me what the difference is between the different range of plugs? (Eg. 5, 6, & 7)
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 08-11-2006, 04:55 AM   #978
Trader Rating: 13 (93%+)
hey guys i just got a mega zx .21 dsII off my mate thats had 1 idle tank and 5 tanks with load driving the car and slowly leaning.
can some one give me the stock needle settings pleasE?
plus any info regarding these engines thatw illcome in handy
thanks!
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 08-11-2006, 07:12 AM   #979
M7H
M7H's Avatar
BB
In general:
lower number = thinner wire = hotter plug.
Higher number = thicker wire = colder plug.
colder plugs are used in warmer wheather conditions.
Serpent
Old 08-11-2006, 09:53 PM   #980
Default modifying .21 DSII?
has anyone tried any simple mods to this engine to increase power or make it run a little more effiecient ?
thanks
Old 08-11-2006, 11:30 PM   #981
Bundy_Bear's Avatar
In general:
M7H:
Thanks for that... I have been told because i am using low nitro content i should be using a "hot plug"... so with your suggestion would a 7 hot be the go then? I will be running 16% nitro and it is downunder here is sunny (hot) Qld...
Look forward to your reply
BB
MissMooRC Racing
Old 08-12-2006, 08:15 PM   #982
thanks
I don't think anyone likes to give away secrets...
Luke W is offline   Reply With Quote
Old 08-13-2006, 03:14 PM   #983
M7H
M7H's Avatar
M7H:
BB
You just have to try.....
(Not the answer you were looking for probably...... )
But here in Holland, the EFRA rule is also 16%, and they are all running this engine with 6 or 7 plug as far as I know.....
thanks
Making mods which saves fuel?......
Serpent
Old 08-13-2006, 10:16 PM   #984
efficient meaning nicer power
Old 08-14-2006, 03:20 AM   #985
M7H
M7H's Avatar
It allready has nice power...
Serpent
Old 08-15-2006, 08:12 AM   #986
Default Mega ZX21 DSII Race needle settings ?
hey guys i cant find the standard needle settings anywhere
can someone please give me these ? thank you very much
also has anyone found out the difference between the 2 engines that have the 7 or 8 fin head ?
thank you
John
Old 08-15-2006, 07:03 PM   #987
jag
jag's Avatar
Default ZX12 Rod
I had my first rod failure this past weekend but it was not what I had expected. When I opened it up I found that the bushing on the crank end was gone. The rest of the rod looked fine. Is this what normally happens? I was expecting to find the crank end broken... looking more like a "J" than an "O". It was my fault. I forgot to change the rod when I was supposed to. It was my backup engine and I lost track of how much time I had on it.
I recently replaced the rod in my good engine and I noticed that it was different than the original one. It did not have a bushing in the top. Is this the new (better) rod?
jag is offline   Reply With Quote
Old 08-17-2006, 07:59 AM   #988
Default needle settings anyone please ??
thank you
John
i cant find these anywhere
Old 08-17-2006, 08:11 AM   #989
Send a message via MSN to Qlone
The rod without the bushing at the top is the improved version, yes. It should last a lot longer than the original version.
Where did your bushing go? Did it get loose in the engine and possibly ruin the engine? I have photos of a MAX312 engine where one of the balls of the rear bearing failed and flushed into the combustion chamber:
Not a pretty sight, and it shows why you want to check your engine internals every now and then...
Qlone is offline   Reply With Quote
Old 08-17-2006, 01:27 PM   #990
Hi Mrgsr,
Main needle flush
Low speed needle 2 mm
This is a starter point on the rich side
Paolo
Paolo M is offline   Reply With Quote
WTB: Mega Picco Header and pipe .12 rcfoolz R/C Items: Wanted to Buy 0 10-07-2007 07:46 PM
FS: Mega Picco .21 DSII with spares mrgsr R/C Items: For Sale/Trade 3 12-02-2006 03:09 PM
KYOSHO RRR WCE,Mega picco Carlsen Modifeid GMartinez R/C Items: For Sale/Trade 15 02-08-2006 07:40 PM
^^^ NIB MEGA PICCO ZX12 VERY CHEAP AND USED MEGA PICCO PIPE ^^^ Riketsu R/C Items: For Sale/Trade 2 12-09-2005 03:54 PM
Mega-Picco ZX-12 Pandora's Box Malaysian R/C Racers 52 04-08-2005 01:37 AM
