Old 07-18-2006, 07:14 PM   #931
Originally Posted by SnakeEyz
Does anyone know what the pros and cons are to running the Novarossi carb on the ZX-12 I ve seen this in pictures of people cars and was wondering if the engine performed better this way
You can do it with no problems except that you will have to cut/mod the neck of the Nova carb to fit the ZX-12... Way back when Picco carbs were a piece of crap, alot of racers swap the picco carb out for a Nova... I believe Picco and Serpent worked on and corrected the carb tuning issues with the current line of motors... If you don't like the ZX-12 carb... Give the Nova or even a Sirio carb a try...
RC_Alan
rc_alan is offline   Reply With Quote
Old 07-19-2006, 12:38 AM   #932
Dynamite's Avatar
Send a message via MSN to Dynamite
Originally Posted by Rookie Solara
Does anyone know what is the stock needle setting for the ZX-15 (not 12) engine...? Need to redo the whole setting for the 835 for the upcoming Chicago Mid West Series........thanks guys.
If using on 835 running Centax 2 clutch, do I need to place the 0.5mm shim before the collet? Am I suppose to use the black MEGA collet or the gold colored one from Nova Rossi type? Thanks again...
P.S...Zx15 needle setting same as Zx12?
should be same as zx12
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 07-19-2006, 12:46 AM   #933
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Anyone running the Carlsen Modified GT5 ZX21? I plan to pick one up from a friend for cheap. I seen one at the track, but not sure if it was further modified. Is the same pipe offered with the powerpackage the best one for it?
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 07-19-2006, 10:02 AM   #934
Wanabrc's Avatar
Trader Rating: 70 (100%+)
Thanks for the anwser Solara.
Wanabrc is offline   Reply With Quote
Old 07-20-2006, 10:10 AM   #935
Trader Rating: 16 (100%+)
And do you know what the setting will be on ZX12? Thanks........
Old 07-22-2006, 01:15 AM   #936
Default settings
A starting point for zx12 on 16% nitro would be -
0.4mm head shims
LSN 6 turns out- HSN 5 turns out- idle to suit
C Mike Hunt is offline   Reply With Quote
Old 07-22-2006, 02:24 AM   #937
Dynamite's Avatar
been awhile since i have ran the engine... i think it was low side level with end of slide and high side 5 or 5.5 turns out. i sure i got the information off mytsn a year or so ago, but never wrote it down...
Old 07-22-2006, 01:53 PM   #938
M7H
M7H's Avatar
Originally Posted by Kendall
Now here is the real question you might want to try.... Does the conrod from your DSII fit on the crankshaft of your DSI?
well, I don't know and can not try, because I don't have the crank of my DSI anymore....
But, I believe the answer is allready given.....
Serpent
M7H is offline   Reply With Quote
Old 07-30-2006, 09:54 PM   #939
quietstorm76's Avatar
Hey guys, I got the chance to see a DSII in action this weekend and I am extremely impressed with it performance. The engines being ran at my track range from DSI(what I run) all the way to Murnan Mod 35 plus 21's and everything in between. That DSII revs up so fast and it just kept pulling. The only thing that was faster was a Murnan 35 plus 21 but it wasn't a blow out. $600 vs. $300 ........................... I'll be running a DSII at WinterNats 2007.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 08-05-2006, 01:51 PM   #940
M7H
M7H's Avatar
I keep telling people that, but probably because I'm from Europe, people at rc-tech don't really listen.....
Also the Ninja engines give nice affordable performance.......
There is 1 thing though I think, a DSII, will not last as long as a 35-21.... (for Ninja I really can tell)
BUT, also a Nova based engine can have a faillure, and then you are glad you saved some bucks.....
Serpent
Old 08-05-2006, 03:09 PM   #941
HarKonnenD's Avatar
I look at it the same way. Most swear by JP, but then again people been kickin butt with the OS .12TZ, Mega ZX12 DSII, STS modded .12, etc. Not all the time some who try may be lucky, but some are just better skilled and have more luck than others.
Old 08-05-2006, 03:22 PM   #942
M7H
M7H's Avatar
There have been some issues with the Mega engines, that's something we should not forget, but I am convinced that most of these problems are related to user errors.....
The Mega engines need to be tuned a little different, and if you don't do that.......
They also need a little more maintenance, and if you don't do that......
just my 2 cents.....
Serpent
Old 08-06-2006, 01:17 AM   #943
stefan's Avatar
Send a message via AIM to stefan
Is the .12 DSII released yet? If so, how much is it?
stefan is offline   Reply With Quote
Old 08-06-2006, 12:58 PM   #944
M7H
M7H's Avatar
http://www.the-border.nl/product.php?productid=25136
Serpent
Old 08-06-2006, 01:16 PM   #945
stefan's Avatar
Thanks MH7.
There goes the price advantage of the Mega engines.
I know that the Border is pretty expensive, but the DSII is now more expensive than Novarossi's new Plus12-3.
WTB: Mega Picco Header and pipe .12 rcfoolz R/C Items: Wanted to Buy 0 10-07-2007 07:46 PM
FS: Mega Picco .21 DSII with spares mrgsr R/C Items: For Sale/Trade 3 12-02-2006 03:09 PM
KYOSHO RRR WCE,Mega picco Carlsen Modifeid GMartinez R/C Items: For Sale/Trade 15 02-08-2006 07:40 PM
^^^ NIB MEGA PICCO ZX12 VERY CHEAP AND USED MEGA PICCO PIPE ^^^ Riketsu R/C Items: For Sale/Trade 2 12-09-2005 03:54 PM
Mega-Picco ZX-12 Pandora's Box Malaysian R/C Racers 52 04-08-2005 01:37 AM
