Old 03-19-2006, 06:25 PM   #736
Road Rage:
You can order it to Edwuard, But you also need to verify your crank pin. With a caliper measure it at about 4 diferents points, just to be sure the vrank pin doesn't have an oval shape.
Edgar Millenium is offline   Reply With Quote
Old 03-21-2006, 02:05 AM   #737
Julius's Avatar
Originally Posted by jag
I was assuming that he was measuring the distance between the end of the nut holding the flywheel on and the preload nut (the one holding the spring on). If that's the case it does not matter what cone or shimming you use... right?
Not entirely true. It's the combination of spring preload and clutchgap that determine the engagement point.
Think of two clutches with the same preload but one has a much bigger clutchgap. That clutch would have to move much further against the spring so would engage later.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 03-21-2006, 07:03 AM   #738
jag
jag's Avatar
I understand your point but I was only referring to comment about the consistancy of the preload measurement. The distance you screw the preload nut down is independent of the shim and collet since the nut is tightened against the flywheel. Do you agree?
jag is offline   Reply With Quote
Old 03-21-2006, 07:37 AM   #739
M7H
M7H's Avatar
You were referring to my point, and I agree with You....
You can give a preload in mm, if it is measured from this nut.....
But as Julius said, the engagement point depends on more than only this preload setting, so the gap also plays an important roll here, and that was not mentioned.....
This is why I said that it is "dangerous" to tell that your preload should be ...mm.
Serpent
M7H is offline   Reply With Quote
Old 03-21-2006, 08:30 AM   #740
jag
jag's Avatar
I agree. It's just one part of the puzzle.
Old 03-21-2006, 09:53 AM   #741
Julius's Avatar
It gets worse,
All springs are different too. They are not all of equal length. That makes comparing even more difficult. Agreed the measurement from the top of the clutchnut helps, but you need to add clutchgap, type of weights and spring used to the mix.
Especially when the clutch setting is agressive and late it is very tricky to copy by giving nummbers.
Old 03-21-2006, 10:12 AM   #742
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
I have a omega x7, is a os 8 plug ok for this motor?
1armed1 is offline   Reply With Quote
Old 03-21-2006, 10:40 AM   #743
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Wow, those MF mega engines are lookin sweet!!
http://www.mytsn.com/products/desc.asp?prid=4244
http://www.mytsn.com/products/desc.asp?prid=4245
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 03-24-2006, 01:14 PM   #744
Does anybody know when the new Mega ZX 12's (with the new conrod) be in the United States, Serpent's page said the updated Mega ZX 21 will be realeased early April.
And will the prices for these updated Mega's be the same as the current ZX 12 and ZX 21?
If so that would be great!
Kendall is offline   Reply With Quote
Old 03-24-2006, 01:19 PM   #745
Originally Posted by HarKonnenD
Harkonnen,
First batch of Mega MF, both 12's and 21's are going to be in USA early next week.
Serpent USA
Paolo M is offline   Reply With Quote
Old 03-24-2006, 01:21 PM   #746
Kendall,
ZX12 with new conrod are in stock already.
Serpent USA
Old 03-24-2006, 02:09 PM   #747
Paolo answered faster than me
That's correct, right now we have them available.
Just visit our page to see them.
Old 03-24-2006, 03:09 PM   #748
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Originally Posted by Paolo M
Harkonnen,
Serpent USA
Any hint on what the price tag will be?
Riketsu is offline   Reply With Quote
Old 03-24-2006, 03:52 PM   #749
Paolo thanks for the info about the Mega 12's. That's good news.
What are the prices for the Mega MF 12 and Mega MF 21?
Old 03-24-2006, 05:33 PM   #750
RIketsu and Kendall:
We are going to have them, I have the price already but I think is not a good idea to post it here. Contact me and I llet you know.
Edgar
WTB: Mega Picco Header and pipe .12 rcfoolz R/C Items: Wanted to Buy 0 10-07-2007 07:46 PM
FS: Mega Picco .21 DSII with spares mrgsr R/C Items: For Sale/Trade 3 12-02-2006 03:09 PM
KYOSHO RRR WCE,Mega picco Carlsen Modifeid GMartinez R/C Items: For Sale/Trade 15 02-08-2006 07:40 PM
^^^ NIB MEGA PICCO ZX12 VERY CHEAP AND USED MEGA PICCO PIPE ^^^ Riketsu R/C Items: For Sale/Trade 2 12-09-2005 03:54 PM
Mega-Picco ZX-12 Pandora's Box Malaysian R/C Racers 52 04-08-2005 01:37 AM
