Old 12-28-2005, 05:55 AM   #661
Default bearing
i think they would make it better ,due to less rotating friction. i just don't know where to get any the te zx-12
isuzuguy is offline   Reply With Quote
Old 12-30-2005, 10:35 PM   #662
jag
jag's Avatar
Default Wrist Pin
I am trying to change the connecting rod on my ZX12 and I can't get the wrist pin out. I have removed both G-clips and pushed it from either side and it won't budge. Is there some other method of removing it that I am not aware of? Is it pressed in? I thought they were floating.
jag is offline   Reply With Quote
Old 12-31-2005, 01:39 AM   #663
Julius's Avatar
They can be hard to get out. In this case I use a heat gun to heat the piston a bit first. Then I stick a 1.5mm hex driver or similar into the wrist pin (into the open side of the wrist pin) and tap it out using a big handled screwdriver on the hex driver. I support the piston during this procedure on a soft wooden block with a hole drilled in it where the wristpin can come through. As long as you use gentle taps you'll have no problems.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 12-31-2005, 02:08 AM   #664
The problem is due to some mushrooming and burring of the edges of the circlip groove. The burrs can be carefully scraped away on one side and the pin will push out as described by Julius without hammering.
DO NOT chamfer the groove by cutting too deep. Just light scraping square to the hole.
C Mike Hunt is offline   Reply With Quote
Old 12-31-2005, 07:57 AM   #665
jag
jag's Avatar
Thanks guys. I will give it a try.
Old 12-31-2005, 09:46 AM   #666
jag
jag's Avatar
That worked perfectly. To push the pin back in I put a hinge pin in my drill press and gently pushed it back in. Now if I can just find a G-clip to replace the one I bent I will be finished.
Old 01-02-2006, 03:42 AM   #667
M7H
M7H's Avatar
NEVER re-use a G-clip.....
always put in new one's.........
And take some spare one's, just in case they jump through your room....
Serpent
M7H is offline   Reply With Quote
Old 01-02-2006, 11:07 PM   #668
Dreddlox's Avatar
How does the Mega ZX-21 compare to the other .21 race engines out there? How is the durability?
Dreddlox is offline   Reply With Quote
Old 01-06-2006, 07:26 PM   #669
Hi Guys:
I don't know if this has been anounced before, but serpent USA have the new conrods available, by now all engines will come with the new conrod apart, so you can make breaking with the old one and then change it to the new one. If you are interested on any engine, we have power packs with a very good price. Just visit the web page link below.
Edgar Millenium is offline   Reply With Quote
Old 01-07-2006, 07:51 PM   #670
jag
jag's Avatar
Originally Posted by Edgar Millenium
Hi Guys:
What's different about the "new" rod?
Old 01-07-2006, 07:55 PM   #671
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Well, if the new rod Edgar is talking about is the one from Palmaris Engines. Then the difference is the material used on the conrod.
Riketsu is offline   Reply With Quote
Old 01-07-2006, 08:42 PM   #672
JAg and Riketsu:
I will verify if they are the palmaris with other name, if yes , the difference are in the material used. Right now I still using the palmaris ones on my engines, without any sings of stretching or damage.
Old 01-08-2006, 03:41 AM   #673
Send a message via ICQ to _cyclops_
Are there still delivery problems with the Picco conrods?
_cyclops_ is offline   Reply With Quote
Old 01-08-2006, 07:16 AM   #674
Cyclops:
You can verify wiht your local serpent dealer, right now they are available with new engines, doesn't know if they are available separate.
I will verify on Monday and let you know.
Old 01-08-2006, 10:31 AM   #675
New Mega ZX12 Conrod (by Picco)
Well guys, Edgar was a little bit faster anouncing but anyway, no harm done
We have the latest conrod by Picco. Now, beside having awesome performance at a very good price level, we have also reliability. We have already stock of rods as spare parts. The engines we have in stock (both engine only and Powerpack) will be supplied with the old conrod installed (we reccomend to use it only for breaking in the egine) and the new one as a spare at no extra cost. After we sell all our inventory, the new batch will come with the new one already installed.
Paolo
Serpent USA
Paolo M is offline   Reply With Quote
WTB: Mega Picco Header and pipe .12 rcfoolz R/C Items: Wanted to Buy 0 10-07-2007 07:46 PM
FS: Mega Picco .21 DSII with spares mrgsr R/C Items: For Sale/Trade 3 12-02-2006 03:09 PM
KYOSHO RRR WCE,Mega picco Carlsen Modifeid GMartinez R/C Items: For Sale/Trade 15 02-08-2006 07:40 PM
^^^ NIB MEGA PICCO ZX12 VERY CHEAP AND USED MEGA PICCO PIPE ^^^ Riketsu R/C Items: For Sale/Trade 2 12-09-2005 03:54 PM
Mega-Picco ZX-12 Pandora's Box Malaysian R/C Racers 52 04-08-2005 01:37 AM
