Old 09-27-2005, 02:21 PM   #586
Default Cutting off on throttle
Im having an issue with my mega ZX12. very often after i go throug the technical part of the track and head for the long straight the motor cuts off halfway down the long straight. Often i hear a "pop" like a backfire. It is fine on the other parts of the track however but it acts up when i have it wide open on this back straight. Any suggestions?
Maxx is offline   Reply With Quote
Old 09-27-2005, 09:12 PM   #587
Default gaskets
what the part#of the gasket between the header and pipe
isuzuguy is offline   Reply With Quote
Old 09-28-2005, 01:31 AM   #588
Dynamite's Avatar
Send a message via MSN to Dynamite
richen it up a smidge on top end and try, only a small amount like 1/12th turn and see what happens - almost sounds how i would describe how my zx12 behaves when its a smidge too lean on top end.
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 09-28-2005, 08:10 PM   #589
Thanks, ill give it a shot this weekend.
Old 10-05-2005, 05:40 PM   #590
paulfitipauldi's Avatar
change your plug, and that will cure youre problem,, I have the same problem with a Mega Picco plug,, thats what I switch to Dynamite medium, and problem gone
paulfitipauldi is offline   Reply With Quote
Old 10-05-2005, 05:48 PM   #591
Originally Posted by crashed_1
Anyone know if OS plugs work well with the ZX12?...Where I live it's kinda difficult to get hold of the MEGA plugs.
Don't even try it, this plug will not sit properly
Old 10-05-2005, 08:58 PM   #592
ElectricConvert's Avatar
Could it be the plug?
I experienced this same symptom a month ago until I realize that I was still using the same plug from breaking in the motor. Changed the plug and the problem was fixed.
I get my gear from shop.the-border.nl. (There's a plug for you Michel)
ElectricConvert is offline   Reply With Quote
Old 10-06-2005, 07:04 AM   #593
crashed_1's Avatar
I learned the hard way...blew three plugs(OS) within 1 tank...
crashed_1 is offline   Reply With Quote
Old 10-06-2005, 06:39 PM   #594
Thanks for that advice all.
Old 10-07-2005, 07:55 PM   #595
Originally Posted by M7H
The new conrods are available for... 1 month?....
so if it's older you have the previous version......
HI!
I am a serpent Dealer, and as far we know mega picco engines in US still have the original conrods. I just received an order of conrods last friday and they still the old ones. Serpent_USA haven't notified us about if there any new conrod available.
Edgar Millenium is offline   Reply With Quote
Old 10-07-2005, 07:59 PM   #596
Mega Picco engines like to run a little rich in top speed. It sounds that you are running a little lean, also the back fire could be hot plug. What plug are yuo using?
Old 10-07-2005, 08:01 PM   #597
Originally Posted by Riketsu
Anyone know the bearing sizes for the Mega Picco ZX-12? Or where I can obtain Ceramic Ball Bearings for it?
Riketsu:
I have the inner ball bearing available, call me you know where!!
Old 10-07-2005, 08:05 PM   #598
Originally Posted by Dynamite
doesnt appear to be, pulled the rest of it all apart last night. everything appears to be in order... and if the rod didnt swing around and smash the skirt on bottom of the piston i would only need another rod...
pitty as motor still had abit of compression, not that it ever had the 'nip' at the top of a nova motor even when brand new out of the box.
now i need a new p/l & rod set, cranks fine bearings are all fine and shrapnell now removed.
Dinamite:
You were very lucky to run that much on your engine. Mostly I change my engine's conrod, every 2 hours of racing. I normally see a X.X3 increase in gap after that time. If you still looking for the P/S and Conrod, we have them available, just contact us for info at [email protected]
Old 10-07-2005, 08:47 PM   #599
EdwardN's Avatar
Originally Posted by Edgar Millenium
HI!
There are new conrods available for Mega/picco motors, much stronger and last at list 5-6 gallons of fuel. Palmaris Racing offering them.
Check www.palmarisracing.com
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 10-07-2005, 09:06 PM   #600
I just sent them an email asking for more info, becuase it doesn't show retail price or dealer info.
WTB: Mega Picco Header and pipe .12 rcfoolz R/C Items: Wanted to Buy 0 10-07-2007 07:46 PM
FS: Mega Picco .21 DSII with spares mrgsr R/C Items: For Sale/Trade 3 12-02-2006 03:09 PM
KYOSHO RRR WCE,Mega picco Carlsen Modifeid GMartinez R/C Items: For Sale/Trade 15 02-08-2006 07:40 PM
^^^ NIB MEGA PICCO ZX12 VERY CHEAP AND USED MEGA PICCO PIPE ^^^ Riketsu R/C Items: For Sale/Trade 2 12-09-2005 03:54 PM
Mega-Picco ZX-12 Pandora's Box Malaysian R/C Racers 52 04-08-2005 01:37 AM
