MEGA (by Picco) thread
Old 05-23-2005, 12:57 PM
  #466
roadrage's Avatar
Trader Rating: 14 (100%+)
what kind of glow plugs/ numbers do you use on your mega .12?
roadrage is offline
Old 05-23-2005, 01:47 PM
  #467
gonzoY5's Avatar
I've used 6/7 Cold. So far those were all that was available. I think they just got the Warms in.
gonzoY5 is offline
Old 05-24-2005, 12:48 AM
  #468
theRED5's Avatar
mine had another 1/4 gallon through it yesterday...Still doing TQ's and winning races.
Although, I did pick up a conrod from my parts guy last week.
theRED5 is offline
Old 05-24-2005, 03:23 PM
  #469
Dreddlox's Avatar
For any one in need fo the O-rings, Winner's Circle has them in stock. I just got the engine this past weekend and noticed the O-ring sticking out of the low-end of the carb. Go to gasrccar.com, you can call and order it. Part #202073.
Dreddlox is offline
Old 05-24-2005, 03:36 PM
  #470
Sow&Steady's Avatar
Red5, I've heard various recommendations about changing conrods - anywhere between 5 to 10 litres. What's your or anyone else's opinion(s)?
Sow&Steady is offline
Old 05-24-2005, 03:48 PM
  #471
gonzoY5's Avatar
It's crazy, I've seen a few go within a gallon and then I know a guy who has one from the First batch that became available and he runs every weekend and it's still going strong. So who knows what to believe.
gonzoY5 is offline
Old 05-24-2005, 04:46 PM
  #472
Riketsu's Avatar
Trader Rating: 33 (100%+)
Default % of nitro
What % of nitro and brand are you guys using with your ZX-12?
Riketsu is offline
Old 05-24-2005, 05:40 PM
  #473
roadrage's Avatar
30% o'donnel
roadrage is offline
Old 05-24-2005, 08:19 PM
  #474
gonzoY5's Avatar
30% Maxy's Fuel.
gonzoY5 is offline
Old 05-27-2005, 04:41 AM
  #475
M7H
M7H's Avatar
Originally Posted by Finken
Info from Serpent:
They are testing new conrods for the.12 engine now, if its working good, it will be available late jun.
and what about the .21 engine?
Here is something nice i've noticed in the engine's manual.
It say's to replace the conrod every 5-8 hours of running.
The older NovaMega engine manual advises to replace the conrod every 12-15 hours of running.
Does this mean that the materials used in the Mega are by default of less quality the the older Nova based engines?
M7H is offline
Old 05-27-2005, 09:48 AM
  #476
Riketsu's Avatar
Could be... Or it could be that the new Mega Picco pulls too much power for it to withstand 12-15 hours of running. There for its adviced to be changed each 5-8 hours.
Riketsu is offline
Old 05-28-2005, 08:41 PM
  #477
1FastSerpent's Avatar
It's gotten to the point of these newer motors are making so much Power & torque that you are starting to find weak spots. You don't see Top fuel Funny cars making more then 1 pass down the track before rebuilding the motor. Same with nascar Or Formula 1 . they run 1 - 2 races for formula 1 now , And Nascar goes 500 miles. It's called the RAGGED Edge
I don't think it is so much being a ( cheap material ) as too the rpm that this zx 12 can turn. It's like it will never flatten out.... but something has to give.that being the rod.I think a newer rod is in the works but I also think it will lower the RPMs because of the weight of the rod. if they make it thicker.
1FastSerpent is offline
Old 05-29-2005, 07:21 AM
  #478
Pyramid's Avatar
Interesting point of view
Pyramid is offline
Old 05-29-2005, 12:10 PM
  #479
M7H
M7H's Avatar
Well at least, the Mega/950R combo, with our Belgium neighbour Steven Cuijpers behind the wheel, did a nice job at the European B Championship, because they won it.......
M7H is offline
Old 06-07-2005, 05:41 PM
  #480
Riketsu's Avatar
Default Another conrod bites the dust
Heres a pic of a Mega Picco ZX-12 3 port with the broken conrod.
Riketsu is offline
