Old 04-27-2005, 07:55 AM   #391
Send a message via Yahoo to speedy100
Default Re: Re: Re: Re: Re: Re: Con-rods in need of replacing.
Originally posted by joemugen
thats a good question for paolo. my guess would be that the conrod for the .21 is thicker.
serpent deserve to do somthing for those who have bought the motor rather than they do nothing.....to be frank, the motor is pretty fast but the rod issue let everyone step out...
speedy100 is offline   Reply With Quote
Old 04-27-2005, 08:00 AM   #392
Regional Moderator
daniz24's Avatar
Default Re: Re: Re: Re: Re: Con-rods in need of replacing.
Originally posted by speedy100
the 0.21 motor has more punch but it does not seem they wear fast.........why would the broken rod happened in 0.12 as I assume they are same material...............???????????????????
The same questions are why .12 engine lost its compression faster and more difficult to tune than .21 engines?
daniz24 is offline   Reply With Quote
Old 04-27-2005, 08:48 AM   #393
EdwardN's Avatar
Hey Deniz.
No it doesn't loose compression faster.
12 engines has smaller piston diameter and tollerances on smoller sizes are tighter then on bigger. If you look 60, 65 or 90 size engines, they last much longer. Pistons there is etween 25-29 mm diameter and tollerances there is much greater.
Edward
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 04-27-2005, 08:58 AM   #394
EdwardN's Avatar
Picco company been in bussines I think more then 25 years and this means something. If you know how many records were set up by using PICCO engines you will be ammezed. They had issue with conrods and I do belive it was fixed. This is one of the company which I belive can be trusted to their expirience and expertise. I saw their engines running and they are pretty good. I am sure something can be improove there, I would make P/S set with conrod (not because they are bad, because I have different view and different theory on porting), 12 mm cranck is very good idea and I am sure they are much stronger then 11.5 mm. It can be lightened, I have idea where extra metall can be remove from cranck, but have never had one for experiments. May be one day I will put my hands on it
Edward
Old 04-27-2005, 08:08 PM   #395
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I just got my engine back from Serpent, from day 1 it ran at 290+...it even reached 342!, but I sent it back to Serpent and had them go over it. They replaced a few items and said it was "A-OK". Replaced the con-rod, plug, carb O-ring and put some extra shims in it. Took it out to play today, it was at 270. Worked on carb settings for over an hour, but got the temps down to 213 doing speed runs up and down my block. Had the dogs chasing it, (actualy, I turned the car around and chaised them a bit too) ),
But what I discovered was that the engine is a pain to tune, it needs to be tuned differently than any other. I tuned it for running, not idling. If I was doing a standing start, the engine would load up and shut off on me in about 30 seconds. But if you run it, it clearss out quite well and runs FAST as HELL and stays cool. I'm 4 3/4 turns out on the bottom and 3 1/2 on the top. It looks like a fog machine, but got 6 min chaising the dogs around. Going to race it this weekend. If it gives me any issues, its outa there and the Novarossi is back in.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 04-27-2005, 08:32 PM   #396
nitrodude's Avatar
PIcco based .12s are notorious for being hard to tune. The carb cant hold a tune, you have to keep after it more so than other engines. What I did was to put a Nova carb on it, and then the engine runs very good, pretty fast too.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-27-2005, 08:49 PM   #397
InitialD's Avatar
Ed, I'll be eager to wait for you to make a "hop up" for this engine.
Old 04-27-2005, 08:50 PM   #398
InitialD's Avatar
Are you referring specifically to the Mega engine or the Picco?
Old 04-27-2005, 09:54 PM   #399
rcfoolz's Avatar
Will a novarossi carb fit in the zx-12 engine?
Old 04-27-2005, 09:55 PM   #400
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
yes it will,i put one on my werks picco xpr 12 and it is almost a carbon copy of the mega picco
Old 04-27-2005, 10:47 PM   #401
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Default Re: Conrods
Im wondering if the engines that suffered the broken conrod after 1 gallon were modified or stock?
Riketsu is offline   Reply With Quote
Old 04-28-2005, 12:45 AM   #402
InitialD's Avatar
Just browsed some results from the Ozzy New South Wales Championships...
Pos Driver State Car Engine Laps Time
1 D Campbell NSW Serpent 710 Mega 93 1814
2 K Hazell NSW Kyosho RB 91 1809
3 A Millford QLD Mugen JP 90 1816
4 J Davis Vic Mugen JP 88 1800
5 P Woodbury NSW Kyosho JP 88 1815
6 S Camelleri S.A Mugen JP 83 1815
7 C Hawkins NSW Kyosho RB 80 1802
8 A Bardetta NSW Kyosho RB 72 1800
9 S Grant NSW Serpent 710 Mega 34 1800
10 C Reade NSW Mugen JP DSQ DSQ
Although by right no. 10 won the race, it's a worthy mention that the Mega triumphed in the field of JP, RB and Max engines.
If any of you down under guys saw or participated in this race, perhaps you could chip in a thing or two on what you witnessed.
Old 04-28-2005, 12:47 AM   #403
M7H
M7H's Avatar
Default Re: Re: Conrods
That's a nice question......
Serpent
M7H is offline   Reply With Quote
Old 04-28-2005, 02:06 AM   #404
rcfoolz's Avatar
I don't think any of the engines need modding. This thing runs the pants off just about everything out there stock. The 2 that I have seen were box stock that popped.
Old 04-28-2005, 11:16 AM   #405
teammpp's Avatar
All the ones I have seen break conrods are totally stock. I was told by a factory team driver that Serpent has told them they have to run the engines standard at the moment.
Whether its true or not I dont know. What I do know is the power difference between the team drivers and the joe blogs was not normal
I might be loosing the edge on some parts of the body with age but my eye sight and hearing is still perfect ( I hope)
teammpp is offline   Reply With Quote
WTB: Mega Picco Header and pipe .12 rcfoolz R/C Items: Wanted to Buy 0 10-07-2007 07:46 PM
FS: Mega Picco .21 DSII with spares mrgsr R/C Items: For Sale/Trade 3 12-02-2006 03:09 PM
KYOSHO RRR WCE,Mega picco Carlsen Modifeid GMartinez R/C Items: For Sale/Trade 15 02-08-2006 07:40 PM
^^^ NIB MEGA PICCO ZX12 VERY CHEAP AND USED MEGA PICCO PIPE ^^^ Riketsu R/C Items: For Sale/Trade 2 12-09-2005 03:54 PM
Mega-Picco ZX-12 Pandora's Box Malaysian R/C Racers 52 04-08-2005 01:37 AM
