Old 04-26-2005, 03:14 PM   #376
teammpp's Avatar
Originally posted by Marcos.J
does your BRB sets include a conrod?
yep, all come with conrod
teammpp is offline   Reply With Quote
Old 04-26-2005, 03:41 PM   #377
Originally posted by Top Gun 777
I saw conrods blew up on every single brand, including airmodeling and boating-no one brand has insurance. Some of the brands is better, some of them really bad, but again it does happened to every single brand-no exceptions. I think it depends of price-more expencive last longer, due the high cost of materials. Not every bronze will work there, not every Al alloy will stay on conrod. If something cheap-it means cost of production is cheap, materials are cheap, so low quality.
i do see what you are saying, but you go by probabilities. the probability of a novarossi conrod braking is so much slimmer than that of a pico (mega). i personally have never seen a novarossi conrod break. i am not saying that it will not happen. but i am saying in the limited amount of time that i have seen the pico run i have seen four conrods go.
Joe Chaplow is offline   Reply With Quote
Old 04-26-2005, 03:48 PM   #378
M7H
M7H's Avatar
Last Year when Serpent still had the Nova based engine, a driver I know blew up 5! engines in 2 weeks....
Your wright, it wasn't the conrod, but the piston.......
Serpent
M7H is offline   Reply With Quote
Old 04-26-2005, 03:58 PM   #379
teammpp's Avatar
ouch. I really feel that hurt my pocket just thinking about it.
All engines have flaws somewhere. Whether it be conrod, piston or hard to tune carbs. Its a trade off between reliability and raw power and each manufacture makes the decision to compromise whatever part they feel will give best performance with least problem.
Nova believe a really tight fit P/S is best for producing power but the downside is they fail if break in is not done properly (with care) and sometimes they just fail anyway regardless.
Old 04-26-2005, 04:10 PM   #380
EdwardN's Avatar
No you took me wrong. I am not saying that probability is the same, what I try to say-it is every brand has no "insurance" against broken conrds. I do have my own statistic for almost every single brand with "phisical evidence" (for study the issues) and there is a lot of interesting stuff I have collected around the world. I guess Paolo has sad before that they did have problem with conrdos and issue was fixed. Not that often you can see when Manufacturer accepted issue. Just for instance, Novarossi made 421 P AAC design, then after 2-3 month they realized it was wrong attempt and they stop making AAC, but they have never accepted or replaced any broken sleeve, at list I have never heard here in LA. I personaly respect Mega managment for this thing.
Edward
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 04-26-2005, 04:11 PM   #381
roadrage's Avatar
Trader Rating: 14 (100%+)
would a different brand of con-rod fit to prevent from buying and buying them?
Austin Wolfe
Serpent America-Trinity/Revtech-www.ActivRC.com
roadrage is offline   Reply With Quote
Old 04-26-2005, 04:15 PM   #382
EdwardN's Avatar
Nope, everthing within brand can be exchangable, but from brand to brand in most cases no. I know Sirio Sleeve almost indentical to Novarossi ( 3.5 size) but hole for wrist pin is 0.5 mm higher then on Novarossi. I did tryed to put Sirio set in Nvarossi with Novarossi conrod, but timing on Transfer was way to high and engine was uncontrolable (very bad). I did for fun.
Old 04-26-2005, 04:54 PM   #383
RayJ's Avatar
Default Con-rods in need of replacing.
If your engine starts popping plugs one after another, and the basic engine tune ambient temp etc stayed the same then i start suspecting con-rod as well.
I'm kind of curious as to what kind of hard facts data Joe Mugen has when he labels mega picco's as engines with bad con rods??
RayJ is offline   Reply With Quote
Old 04-26-2005, 04:59 PM   #384
Default Re: Con-rods in need of replacing.
i have personally witnessed 4 condrods go bad. i know a "team" driver in particular--- not naming names--- have atleast two go, maybe three--- i witnessed one of his.
Old 04-26-2005, 05:08 PM   #385
gonzoY5's Avatar
Joe and I live in MIami, home to Serpent USA. When those engines came out, all the locals here had em, and within a month of running, I started hearing about a popping con-rod issue. Spoken with several Serpent USA drivers that say the same. Seen a few of em go myself. It's pretty bad. I have it and i'm scared to run it. I have like 2 conrods sitting in my bench, i might jsut sell them and run it till it pops. It really is a shame, the engine does perform how they said it would.
gonzoY5 is offline   Reply With Quote
Old 04-26-2005, 05:47 PM   #386
don't get me wrong... i think these engines are the fastest out there. to tell you the truth, i could probably handle the rod issue. i would just replace it every gallon, because i like the power. but now my engine has the leaning out issue as well. no matter what i do, the engine goes to 300+. paolo even spent time with me trying to get the engine to run right. i have also talked to an ex-fully sponsored team driver and he was telling me how serpent used pico a whiles back and they also had issues with rods and stuff and so they went back to novarossi.
also, serpent is not replacing conrods that went bad. they maybe admitted there is a problem with them, but they will not replace for free. they did replace the cranks on the .21 though.
Old 04-27-2005, 03:58 AM   #387
Send a message via Yahoo to speedy100
Default Re: Re: Con-rods in need of replacing.
I was wondering why the rod issue only happened in 0..12 and 0.15. the guys running 0.21 does not seem to have rod issue. I beleive they both are the same material in the rods...........
speedy100 is offline   Reply With Quote
Old 04-27-2005, 06:40 AM   #388
Default Re: Re: Re: Con-rods in need of replacing.
i do not know why. i was told the bushing in the .12 rod is softer than that of a novarossi. this causes the rod to wear faster.
Old 04-27-2005, 06:51 AM   #389
Default Re: Re: Re: Re: Con-rods in need of replacing.
the 0.21 motor has more punch but it does not seem they wear fast.........why would the broken rod happened in 0.12 as I assume they are same material...............???????????????????
Old 04-27-2005, 07:42 AM   #390
Default Re: Re: Re: Re: Re: Con-rods in need of replacing.
thats a good question for paolo. my guess would be that the conrod for the .21 is thicker.
WTB: Mega Picco Header and pipe .12 rcfoolz R/C Items: Wanted to Buy 0 10-07-2007 07:46 PM
FS: Mega Picco .21 DSII with spares mrgsr R/C Items: For Sale/Trade 3 12-02-2006 03:09 PM
KYOSHO RRR WCE,Mega picco Carlsen Modifeid GMartinez R/C Items: For Sale/Trade 15 02-08-2006 07:40 PM
^^^ NIB MEGA PICCO ZX12 VERY CHEAP AND USED MEGA PICCO PIPE ^^^ Riketsu R/C Items: For Sale/Trade 2 12-09-2005 03:54 PM
Mega-Picco ZX-12 Pandora's Box Malaysian R/C Racers 52 04-08-2005 01:37 AM
