Old 03-30-2005, 08:49 AM   #271
Originally posted by GoldFinger
Good Morning....
1st, thank you for detail explanation.
About the fuel, thanks to clarify that and we do agreed that this engine is extremely well while using 10% oil or less.
And the durability is awesome, recently we overcooked 2 engine, 190 and 175 deg C (using 30%nitro+11%oil) and no problem after that, untill today(almost 3rd gallon).
About 2 turn out LSN, I was confused. Maybe there is some difference on full closed position. All of our MEGA.12 was using 4.5 to 5.5 turns out (around 1.2 - 1.5 mm out !!). Leaner than that, initial torque is weaker and sometimes temp will raising rapidly. (sea level,29-33C ambient, 75-90% humid, asphalt temp could reach 65C).
1 more question Mr Paolo, if you dont mind...
How is the detail of your clutch setup ?
On tight/technical track with max. ratio we still feel some delay. Especially after very slow hairpin, we need more punch to came out. And taking Mr. Art word.. "CannonBall" .. yah, we miss that feeling.
GoldFinger,
I have found that sometimes the LSN have some diffenrences in length. So is not really a good indicator the # of turns. I think that the pinch procedure (described in a previous post) is much more accurate and for sure safe.
About clutch setup, i have tried different solutions . and so far the best solution is: std flyweigths, yellow pads, 1.8mm spring (part 909518), 0.7mm end play and 1.7mm more or less pre load (from top of clutch nut to preload adj collar).
Important is also the pipe. If you doon't use the 2607 you will mes a lot of bottom
Paolo
Paolo M is offline   Reply With Quote
Old 03-30-2005, 08:59 AM   #272
Trader Rating: 16 (100%+)
Originally posted by Pyramid
For your reff (pipe in powerpack may have been different for each country),
SER-201201 MEGAPOWERPACK ZX15 SMALL BLOCK
Thanks for the info.............and thanks Paolo.
I have friend got his Zx15 powerpack with the NOVA MEGA pipe set........yes, NOVA MEGA..........don't know where he can still find new Nova Mega pipe but that is what he got from the hobby shop.
Thats why I want to ask Paolo about the specific # of the pipe that ZX15 powerpack came with.
Old 03-30-2005, 09:44 AM   #273
The ZX15 powerpack (MEG 201201) we have in stock at the moment have the Mega 2607 pipe set inside
Paolo
Old 03-30-2005, 09:46 AM   #274
Paolo
.......and the ZX12 Outlaw powerpack (MEG 201006) have the NMega (Efra 2602)
Paolo
Old 03-30-2005, 03:38 PM   #275
revzalot's Avatar
Will O'donnel RTR 20% Nitro work for breaking in the ZX21? What's nitro % is it shimmed for?
revzalot is offline   Reply With Quote
Old 03-30-2005, 05:42 PM   #276
Yes, the fuel will work. Engine is setup for 25% at sea level.
If you are going to use 30% you need to add 0.10mm shim
Old 03-30-2005, 05:44 PM   #277
revzalot's Avatar
Thanks good buddy!
Old 03-31-2005, 06:17 AM   #278
paolo when you do your pinch test for the lsn where do you pinch ? next to the carb, 1 inch away ???
H STAMEN is offline   Reply With Quote
Old 03-31-2005, 09:49 AM   #279
Good question.......mmmmmmmmm..........
next to the carb without burning my hands..... just kidding..........but yes, close to the carb.
Paolo
Old 03-31-2005, 09:59 AM   #280
paolo,
i am confused about the shimming. we talked before and you advised me to use two .10 shims. should i go back to using only one?
thanks in advance.
Joe Chaplow is offline   Reply With Quote
Old 03-31-2005, 10:54 AM   #281
Originally posted by joemugen
paolo,
thanks in advance.
Joe, read again and carefully and you will see the answer............i am not the type of person than talk back and fort.
Paolo
Old 03-31-2005, 11:43 AM   #282
gonzoY5's Avatar
Default Difference between 2602 & 2607 Pipe?
Paolo, Can you explain how the ZX12 Race will perform differently with the 2602 & 2607 pipe? I had the 2602 and then bought the ZX12 Powerpack that came with the 2607. I haven't run it yet, but I would liek to know how it might behave differently with the 2 pipes. Thanks
gonzoY5 is offline   Reply With Quote
Old 03-31-2005, 11:45 AM   #283
gonzoY5's Avatar
paolo,
thanks in advance.
Sup Joe? Haven't seen you in a bit. Where u been? i'm actually going to the FT next week. I'm FINALLY making it to a state race. See you out there.
Old 03-31-2005, 11:59 AM   #284
that is awesome. i wish i was going, but i will be out of town that weekend. you will have a lot of fun. that track is a very fun track to run on. you should do pretty well. there is a lot of competition. maybe i see you this weekend at royalpalm (i do not know if you will be going or not). i have been busy lately, so have not made it out there in a while.
Old 03-31-2005, 07:08 PM   #285
GoldFinger,
Paolo
Hi,
Once I saw you mention 1.7 pre-load.. what a relief for us here. Thanks for confirming that, absolutely we have same engine.. ha ha ..
About the needle quite funny is it? anyway the pinch is very much make sense.. will do.
Agreed with the pipe, in EFRA race NRS 52606 and MAX 02602E is not for this engine. But very wide option for turbo/outlaw pipe.
Good Luck for your racing scene.
GoldFinger is offline   Reply With Quote
WTB: Mega Picco Header and pipe .12 rcfoolz R/C Items: Wanted to Buy 0 10-07-2007 07:46 PM
FS: Mega Picco .21 DSII with spares mrgsr R/C Items: For Sale/Trade 3 12-02-2006 03:09 PM
KYOSHO RRR WCE,Mega picco Carlsen Modifeid GMartinez R/C Items: For Sale/Trade 15 02-08-2006 07:40 PM
^^^ NIB MEGA PICCO ZX12 VERY CHEAP AND USED MEGA PICCO PIPE ^^^ Riketsu R/C Items: For Sale/Trade 2 12-09-2005 03:54 PM
Mega-Picco ZX-12 Pandora's Box Malaysian R/C Racers 52 04-08-2005 01:37 AM
