Old 03-15-2005, 08:55 PM   #211
Send a message via Yahoo to speedy100
Originally posted by afm
OOOPSS!! man, you must be doing something wrong, because you also broke conrods and cranks on the Sirio engines....What fuel are you using??? what oil % does it have, and what temps are you running these engines.
AFM
my guess the motor was rev too high duing the break in so the rod/shaft broken, it also happens when the car is unload off the ground with high revs.
speedy100 is offline   Reply With Quote
Old 03-15-2005, 10:11 PM   #212
Dynamite's Avatar
Send a message via MSN to Dynamite
Originally posted by ziggy12345
Hey Dynamite. Is that bthe Tamworth in the UK? I ,live near there and there is no RC club there.
Australia maybe?
Cheers
Yes I am from Australia
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 03-15-2005, 10:32 PM   #213
Seisick's Avatar
AFM
sidewinder 20 nitro, 12 oil, i quarter open the carb, and 1 turn open from what came from factory 4th tank, running in according to instructions and clutch not tied, 180f, my fault! i dont think so, mega tells to change the conrod after 3 hours, not 3 tanks, just spoke and the engine is on the way to serpent usa since there is warranty and they want to inspect the engine to prevent what happened to the zx21, as i recall there was an issue with the crankshafts, perhaps therell be another with the conrod since they appear to use same low quality material, opps I mean realistically priced material! hope not
the sirios both were from the first batch, the 3 port with the small head (bad conrod) and the 5 port with the old crankshaft (not the racing one) never ran above 220, my track is small and Im easy with the throttle since Im not expert.
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 03-15-2005, 10:35 PM   #214
Seisick's Avatar
i set the epa on the radio to be open 1/4, and believe me this is the 7th engine that Ive done running in and never happened something like this
HobbymaniA
GoT MuGeN?
Old 03-16-2005, 06:25 AM   #215
jag
jag's Avatar
Originally posted by theRED5
I've been waiting on mine to blow, it's been running great, pulls HARD, revs like there's no tomorrow.
Another race weekend under its belt, and still running great. I wonder if the mods Murnan did are keeping it together? What is the problem with the cranks?
I still have the stock crank in mine but I have only run a few tanks after the break-in so I have been very easy on it. I heard that the material used was too brittle and they were breaking. Keep me/us posted on your progress. I don't know if all of the cranks will eventually fail or if they just didn't want to take anymore chances.
BTW, I got my replacement crank last week. I think I like the looks of the old one better.
jag is offline   Reply With Quote
Old 03-17-2005, 06:02 PM   #216
roadrage's Avatar
Trader Rating: 14 (100%+)
are they going to come out with a new batch zx12 motors that have all the problems fixed? because i dont want to get one and the con. rod breaks on me.
Austin Wolfe
Serpent America-Trinity/Revtech-www.ActivRC.com
roadrage is offline   Reply With Quote
Old 03-17-2005, 06:26 PM   #217
i got the new crank last week but there is one turbo scoop, the original crank had 3 scoop i remember. don't know if any difference in the performance wise.............
Old 03-17-2005, 06:32 PM   #218
Originally posted by 1FastSerpent
Speedy100,
I was talking about the 12 not the 21. I run both cars. the 12 has been a very good motor. This motor makes good power all the way around. I ran a 30 min main this past weekend with 30% and I had no problems at all. Nice 210 Degrees And moving like a bullet. I did notice you have to use a stiffer clutch spring with it . The standard 710 spring is too weak. it coil binds before you get a proper adjustment. I used the 950R spring and it really made it come alive on the bottom.
1FastSerpent,
I heard many good things about the 0.12, they say this motors has tones of power and it is fastest. yes, this motor need a harder spring to obtain better perfromance in the bottom.
Old 03-18-2005, 07:56 PM   #219
1FastSerpent's Avatar
Roadrage,
I think the conrod issue with the above guy was a freak thing. Too many of us here in Fl. Are running these 12 Mega motors with NO problems at all. ( Other then the too much torque on the bottom =) . If you run the Forgass series, just ask anyone who is runing it , what they think.
Speedy100,
Your right on about the scoops in the 21 replacment crank. The replacment crank is just that, a replacment. Alot of differences in the intake timming & ventury hole ( center of crank ). Compared to the first cranks, But i Did run the new crank this past weekend and it wasn't too bad. Little soft on top end but not bad.
1FastSerpent is offline   Reply With Quote
Old 03-18-2005, 08:19 PM   #220
teammpp's Avatar
1FastSerpent,
Wonder where they the standard ones or the special black cases ones some of the team drivers have been spotted with
teammpp is offline   Reply With Quote
Old 03-18-2005, 08:52 PM   #221
roadrage's Avatar
[QUOTE]Originally posted by 1FastSerpent
[B]Roadrage,
thanks for the info mark,couple questions:
.how long have you been using your motor,and is it the factory con rod?
.and above i herd you are using thr 950r clutch sping. how is it compared to the stock? thanks
Austin Wolfe
Old 03-18-2005, 09:55 PM   #222
Pyramid's Avatar
You mean Palmaris Engine will never have any future improvement as they never testing any prototypes? Please clarify your posting. Thx
Pyramid is offline   Reply With Quote
Old 03-18-2005, 10:03 PM   #223
I suspect that too since the publicly available engine set doesnt impressed me in any sense. I think I should save my money for something better.
NetBike is offline   Reply With Quote
Old 03-18-2005, 11:05 PM   #224
Seisick's Avatar
[QUOTE]Originally posted by roadrage
[B][QUOTE]Originally posted by 1FastSerpent
[B]Roadrage,
I agree, something happened and that is why serpent us asked me to send the engine, its under warranty and I agree, that engine is fast, Ill let know what happend when serpent usa sends me back the engine with an explanation. anyway powerpack 12 race legal is on the way!
HobbymaniA
GoT MuGeN?
Old 03-19-2005, 06:09 AM   #225
Roadrage,
I have been using my Mega 12 since the winternats. And we have raced 3 other races since then. So I have about 1 gallon on the motor now. As far as the factory rod. Yes the motor is box stock. no mods no nothing. Same type of off the shelf motor you or joe blow would receive.
As far as the clutch spring . the one which comes with the 710 standered ( in the box ) is a tad bit soft for the torque of the new mega 12. you have to tighten it too much to make it have the snap off the corner you need. By tightening it so much , you end up with coil bind. and you will acually hear the motor ( double clutching) off the corner. I use the 950r spring set at .9 mm . Seems to really work well. We are racing in lakeland this weekend. I'll see ya if ya show up.
WTB: Mega Picco Header and pipe .12 rcfoolz R/C Items: Wanted to Buy 0 10-07-2007 07:46 PM
FS: Mega Picco .21 DSII with spares mrgsr R/C Items: For Sale/Trade 3 12-02-2006 03:09 PM
KYOSHO RRR WCE,Mega picco Carlsen Modifeid GMartinez R/C Items: For Sale/Trade 15 02-08-2006 07:40 PM
^^^ NIB MEGA PICCO ZX12 VERY CHEAP AND USED MEGA PICCO PIPE ^^^ Riketsu R/C Items: For Sale/Trade 2 12-09-2005 03:54 PM
Mega-Picco ZX-12 Pandora's Box Malaysian R/C Racers 52 04-08-2005 01:37 AM
