Old 03-14-2005, 03:13 AM   #196
Default ah protosha
mate you need to bet it to the track and run against my monsters
have heard rumours about the engines just cant wait too see what they go like at moorebank at easter hey
Supported by
Harris rc
EA motors
Harris rc batteries
lrp motors,speed passion motors
lrp speedy
AE FT TC5
titanium racing options
aussie racer is offline   Reply With Quote
Old 03-14-2005, 07:26 AM   #197
Pyramid's Avatar
Ziggy.. if you want to run more than 11% oil, go with hotter plugs.
Dynamite, do not worry to experience with this engine.. piston and underhead wont detoriate when overheat. Yes, I'm talking 175-190C (exergen no IR tem gun) overcooked.. you wont see any rough surface as ussually been seen on overheated nova based engine. If they are overheated, just open it up, clean them up (with soap if needed), put it all back on and it will still run like new. The carbs system allows fuel to still flowing on overheated situation. Set the low needle a bit rich for consistant performance on longer run
Pyramid is offline   Reply With Quote
Old 03-14-2005, 07:28 AM   #198
Pyramid's Avatar
... ah, forgot to tell you the most important thing. Do not EVER looked at the smoke, TRUST your temp gun. This bad boys really is a heavy smokers
Old 03-14-2005, 10:03 AM   #199
ziggy12345's Avatar
Have you posted it yet Pyramid? I cant wait to try it!
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 03-14-2005, 10:05 AM   #200
ziggy12345's Avatar
I user Tornado. What oil content is that?
Cheers
Sponsored by:
Norfolk and Chance
Old 03-14-2005, 08:57 PM   #201
Pyramid's Avatar
Cheers
You will be more than fine.. I think the 16% contains 11% if not 10%. Goldfinger will email you shorthly.
Old 03-14-2005, 10:26 PM   #202
Dynamite's Avatar
Send a message via MSN to Dynamite
Thanks pyramid,
richened low 1.5 turns from factory settings and main would be roughly back to factory setting or just slightly richer like 1/12 turn atm. Will need some track time to fine tune it, pitty about working it just always seems to get into the way of good fun lol!
i'll see how it goes on the weekend at our club meeting, has a nice deep herby sound about it just going up and down the driveway motor didnt go over 90'c (degrees 'c) whilst lapping up and down the drive, and sat around mid 60's to low 70'c during the first 5 brake in tanks.
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 03-14-2005, 11:01 PM   #203
Got the 201006 ZX12 outlaw powerpack.After breaking in I'd trouble tuning it with 16% Gammalube fuel. The engine keeps flaming out during half throttle. So I changed the plug to Top's no6 (didn't know about the issue)and switched to 25% fuel. It was still quitting until I found that the problem was a worn out centax clutchshoe.After replacing the shoe the enqine was like a rocket on the low end.So I stick to this plug and fuel.Ran all through 5 heats and a 35 min finals with no problem.And idle was perfect.Only a broken arm prevented me from winning with 3 mins to go and was 3 laps ahead.Now did I do damage to this engine using Top's plug??
Zizu is offline   Reply With Quote
Old 03-14-2005, 11:19 PM   #204
Dynamite's Avatar
I dont think you would hurt the engine by using a top plug, but you might loose a little compression...
I measured the bottom of the conical of the mega plugs i got with my new engine compared to the nova ones i was using on my sirio. the bottom of the conical on the mega plug was 5.2mm compared to 5mm of the nova plug.
Old 03-15-2005, 01:53 AM   #205
Ok. Can't bear the thought of spoiling the engine cos this is one hell of an engine.For me at least.
Old 03-15-2005, 04:48 AM   #206
1FastSerpent's Avatar
Speedy100,
I was talking about the 12 not the 21. I run both cars. the 12 has been a very good motor. This motor makes good power all the way around. I ran a 30 min main this past weekend with 30% and I had no problems at all. Nice 210 Degrees And moving like a bullet. I did notice you have to use a stiffer clutch spring with it . The standard 710 spring is too weak. it coil binds before you get a proper adjustment. I used the 950R spring and it really made it come alive on the bottom.
1FastSerpent is offline   Reply With Quote
Old 03-15-2005, 05:45 AM   #207
ziggy12345's Avatar
Hey Dynamite. Is that bthe Tamworth in the UK? I ,live near there and there is no RC club there.
Australia maybe?
Cheers
Sponsored by:
Norfolk and Chance
Old 03-15-2005, 07:33 AM   #208
Seisick's Avatar
sorry to say this but yesterday the conrod on my zx12 race just broke on the top, i was running in according to the manual and on the 4 tank, bang. will have to send it back to atomic hobbies to see if the warranty covers it. know I know that besides the crankshaft on the 21´s there´ll be an issue on the conrods of the 12. let me get back my digital to post a pic later.
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 03-15-2005, 03:46 PM   #209
afm
afm's Avatar
OOOPSS!! man, you must be doing something wrong, because you also broke conrods and cranks on the Sirio engines....What fuel are you using??? what oil % does it have, and what temps are you running these engines.
AFM
afm is offline   Reply With Quote
Old 03-15-2005, 08:39 PM   #210
theRED5's Avatar
R/C Tech Charter Subscriber
I've been waiting on mine to blow, it's been running great, pulls HARD, revs like there's no tomorrow.
Another race weekend under its belt, and still running great. I wonder if the mods Murnan did are keeping it together? What is the problem with the cranks?
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
WTB: Mega Picco Header and pipe .12 rcfoolz R/C Items: Wanted to Buy 0 10-07-2007 07:46 PM
FS: Mega Picco .21 DSII with spares mrgsr R/C Items: For Sale/Trade 3 12-02-2006 03:09 PM
KYOSHO RRR WCE,Mega picco Carlsen Modifeid GMartinez R/C Items: For Sale/Trade 15 02-08-2006 07:40 PM
^^^ NIB MEGA PICCO ZX12 VERY CHEAP AND USED MEGA PICCO PIPE ^^^ Riketsu R/C Items: For Sale/Trade 2 12-09-2005 03:54 PM
Mega-Picco ZX-12 Pandora's Box Malaysian R/C Racers 52 04-08-2005 01:37 AM
