Old 03-02-2005, 01:43 AM   #166
Dynamite's Avatar
Send a message via MSN to Dynamite
just ordered the new zx12 race powerpack combo and was wondering if anyone has got the specifications for the new zx12 race engine? just like bore/stroke supposed hp yada yada didnt have much luck at mytsn or serpent usa finding this information got plenty of pretty pictures tho.
thanks.
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 03-02-2005, 12:26 PM   #167
Julius's Avatar
thanks.
Congratulations on your new engine.
I have no data on the bore/stroke. You will not find any HP rating for the engine anyway. Serpent has stopped publishing them. As there are no standardised dyno testing facilities the figures from the manf are useless anyway.
If Novrossi were correct with their HP figures, the 200mm cars should run close to 150 km/h....
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 03-03-2005, 09:47 AM   #168
Trader Rating: 16 (100%+)
Nevermind, I've found the answer already, ZX21 is the one to go...
Solara is online now   Reply With Quote
Old 03-03-2005, 02:07 PM   #169
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
is this what the mega picco engine is based on?
they look very similar.
the above one is the Picco xp
Old 03-03-2005, 06:28 PM   #170
Regional Moderator
daniz24's Avatar
How about their price differences?
daniz24 is offline   Reply With Quote
Old 03-03-2005, 11:51 PM   #171
Super Moderator
Marcos.J's Avatar
Old 03-07-2005, 08:51 AM   #172
mo
mo's Avatar
I ran my Mega zx21 for the first time this weekend. I ran pretty good but I was lacking top end to just about everyone else at the track. It had a lot of bottom end, probably too much for the track conditions but I would loose about 15-20ft on the 250ft straight to the majority of people at the track. I was geared the same as other people that are running the same car so I wouldn't think that would be the problem. I don't know if the engine is just lacking RPM or if it is tuned incorrectly. The other thing that was strange about the engine is the carb needles are very hard to turn. Has anyone else noticed this? Also, how do you know if you have one that needs the crank replaced? Any help would be great. Thanks
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 03-07-2005, 09:03 AM   #173
dougday's Avatar
Were you running the mega picco power pack (Pipe & header)?
dougday is offline   Reply With Quote
Old 03-07-2005, 09:03 AM   #174
Super Moderator
Marcos.J's Avatar
i would start with re-setting the carb
Old 03-07-2005, 09:18 AM   #175
mo
mo's Avatar
dougday, I am running a Power Racing Products pipe, which is also being run by others at the track. My local shops don't carry the power packs. What pipe/header comes with the power packs? Where can I find more info about them?
Marcos.J, reset it to what? The factory settings? Are they noted in the instruction book?
Old 03-07-2005, 09:27 AM   #176
dougday's Avatar
Not sure, but I think the part numbers are 2890 and 2892. Give Serpent a call, they could advise you.
I find that the tuned pipes by the engine manufacturer usually works best.
Old 03-07-2005, 09:36 AM   #177
jag
jag's Avatar
I have only had my ZX 21 on the track once so I cannot really compare the power but as the temps got over 200 it really started going. I am still breaking it in so I've been pretty easy on it so far. I also have a Top 321P that has just been broken in so I will be comparing the two.
If you are having trouble turning the low speed needle it's because you have the ball on the end of the slide too tight. The piece that the linkage attaches to. I had the same problem. I just about stripped the low speed screw. My high speed needle is tight but I have not found anything wrong with it.
jag is offline   Reply With Quote
Old 03-07-2005, 09:40 AM   #178
jag
jag's Avatar
The factory settings can be found on the website (mytsn) under the FAQ section for the engine. I found them to be on the rich side... especially the HSN.
Old 03-07-2005, 09:44 AM   #179
InitialD's Avatar
That is correct.
Old 03-07-2005, 10:05 AM   #180
InitialD's Avatar
I believe every engine has different types of characteristics... The Mega engine would need certain type of pipes to compliment the engine's powerband. So a certain pipe might work wonders on certain engines while on others not...
For pipes, I think there are 2 types of powerpack versions available...
201504
ZX21 Race + 2002 Outlaw 2 Chamber Inline Pipe (2890)
201503
ZX21 Race + 2002 EFRA 3 Chamber Inline Pipe (2892)
Some info also on the types of headers that you could use with the pipe posted on the ZX21 FAQ on mytsn;
Answer: we have basically three headers for this engine: 203021, which is the standard header. It has a very good fuleconsumption and a wide powerband and good maximum performance 203024 is a conical header, which improves performance, especially the bottom and power is quite a lot better, but fuelconsumption is higher 203042, this is the header with the highest power output, but also the highest fuel consumption. There is nothing for free!!! Answered by: Michael Salven
So far, no information yet on mytsn on those headers...
On mytsn product page of the ZX21, it states the following;
Dear Ronald, the main needle should be 5 1/2 turn open, and the low speed needle 7 turns. For running in the engine i suggest that the main needle is opened 1 1/2 turn more. Rick V
WTB: Mega Picco Header and pipe .12 rcfoolz R/C Items: Wanted to Buy 0 10-07-2007 07:46 PM
FS: Mega Picco .21 DSII with spares mrgsr R/C Items: For Sale/Trade 3 12-02-2006 03:09 PM
KYOSHO RRR WCE,Mega picco Carlsen Modifeid GMartinez R/C Items: For Sale/Trade 15 02-08-2006 07:40 PM
^^^ NIB MEGA PICCO ZX12 VERY CHEAP AND USED MEGA PICCO PIPE ^^^ Riketsu R/C Items: For Sale/Trade 2 12-09-2005 03:54 PM
Mega-Picco ZX-12 Pandora's Box Malaysian R/C Racers 52 04-08-2005 01:37 AM
