Max Power RP9.0
Old 08-03-2013, 02:31 PM
  #16
I have had volksmotor and rp9. Volksmotor is bad and rp9 is very fast. Nothing in common except the conrod and the bearings.
turbonitro is offline
Old 09-10-2013, 06:10 PM
  #17
Hi, dose anyone know where you can get crankcases for this RP9.0 engine?
Or are there any other crankcases that are the same?
Any information is greatly appreciated.
Cheers.
bucky1 is offline
Old 09-10-2013, 06:46 PM
  #18
MikeCruz's Avatar
Cheers.
Hello,
You can try RCAMERICA for starters
They I know, are a U.S Distributor for MAX POWER Engines
Here is there Phone # (214) 744-2400
I myself also had luck recently with a crankcase needed on the WANT TO BUY ADD THREAD Here on RcTech
Hope this helps... Good luck. Mike...
MikeCruz is offline
Old 09-11-2013, 03:50 PM
  #19
Originally Posted by MikeCruz
Hello,
Cheers.
Appreciated.
bucky1 is offline
Old 09-11-2013, 11:08 PM
  #20
Roelof's Avatar
The MAX is a Novarossi based engine so if you can find any Novarossi based crankcase using the same size bearings, it will fit.
Roelof is offline
