Old 12-19-2004, 03:27 PM   #1
ziggy12345's Avatar
Default Jp Fx/s
Hi
I see JP are bring out a new FX/S .12 engine. ANybody know anything about these?
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 12-19-2004, 04:46 PM   #2
Regional Moderator
daniz24's Avatar
It's the standard version of JP FX (non sleeve modification if i'm not wrong)
daniz24 is offline   Reply With Quote
Old 12-20-2004, 01:27 AM   #3
ziggy12345's Avatar
Any good compared to the moded version?
Cheers
Sponsored by:
Norfolk and Chance
Old 12-20-2004, 06:35 AM   #4
ziggy12345's Avatar
i have been told that the PL set is the same. The only difference is the black case and ceramic bearing. If thats the case these could be the best cheap engine on the market
Cheers
Sponsored by:
Norfolk and Chance
Old 12-20-2004, 10:00 AM   #5
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Cheers
That might not be true, if I am not mistaken, the modded on has some work on the sleeve, say transfer port and some work on the case itself.
Ah10 is offline   Reply With Quote
Old 12-20-2004, 01:58 PM   #6
gonzoY5's Avatar
I have it. Runs great. It's still $300 USD. It's got no HardBlack coating on the insides. The crank is pretty plain except for the silicone filling. There's no "fangs" on the sleeve. It may have the same timing though because it runs like hell. It has standard bearings, and the case is not black. I finally ran the hell out of it though after about 2 gallons. can't get it to idle well or run cool. Time for a new P/S set...heard they're not cheap The box said FX12 T03S
gonzoY5 is offline   Reply With Quote
Old 12-20-2004, 03:00 PM   #7
Ah10's Avatar
Do you still have compression when it is cold? and try to listen from the exhaust port and see if it has leak
Old 12-20-2004, 03:44 PM   #8
ziggy12345's Avatar
Where did you get it from?
Cheers
Sponsored by:
Norfolk and Chance
Old 01-18-2005, 02:48 AM   #9
I have a problem were my engine seems to be running well but every so often it just cuts out (ater 4-5mins or so) were do i start to look for the problem.
I have changed the glow plug and no change?
Iam using a nova rossi Hot plug with 16% synthetic fuel
i would also be great if someone could explain to me why its happening.
Brett.w is offline   Reply With Quote
Old 01-18-2005, 03:09 AM   #10
InitialD's Avatar
Very difficult to tell... How is the idle when you come in back to the pits after say 3 or 4 minutes running? A good engine would idle low and very steadily round after round.
Old 01-18-2005, 01:08 PM   #11
The idle was fine it would just stop for no reason
Old 01-18-2005, 01:24 PM   #12
Ron C.'s Avatar
Is your motor still fairly new?
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 01-18-2005, 01:45 PM   #13
No its about 5 months old its been fine the onmly thing i can think of is the weather, it has been mainly cold when i last used it and i go to use it this weekend and it was very hot. Could this be the cause?
Old 01-18-2005, 04:21 PM   #14
theRED5's Avatar
I have a JP 12 FX T-O3 S engine, and it has no ceramic bearings, no black case, OR factory modified sleeve. I opened it up when it was new and it does not have the "fangs" on the sleeve that other JP's I've seen. That said, it doesn't have a problem staying right there with the modded engines in the club. It was $295.00 from the Mushroom.
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 01-18-2005, 04:25 PM   #15
theRED5's Avatar
Brett, you might try looking at you're red crankshaft filler, the stuff they put in there to smooth out the cut in the intake. I had mine come out, plugging the crank, but it didn't run again until it was removed. But it could be trying to come out.
Mugen MRx4
