break in problems....starterbox not turning the flywheel
im having problems with breaking in a new 12. engine...the compressions so tight the starterbox wont turn it...iv tryed heating it with a hair dryer...any other advice :S
isit worth buying a 12v engine pre heater
hair dryer alone may not produce enough heat. I use a heat gun for my new engines and get the head temp to at least 150* and go from there. You definately want the engine to turn over fairly easily so that the conrod won't take so much abuse trying to turn over a tight piston/sleeve combo.
good luck. |
If that does not do it loosen the glow plug about half a turn and try starting it again.:)
| All times are GMT -7. It is currently 02:08 AM. |
