Old 01-26-2012, 07:27 AM   #31
Originally Posted by Brent Davis View Post
DITTO, that is what I think too. Looking at the sleeves, crank, rod and pistons of all those engines, they are the same with exception of the cooling heads.
No, compared with P Torque, Sonic and Reds.
P Toque got not tear drop and silicone filled in cranksahft, Sonic and Reds almost identical in mod work, expect Reds engine case can drect fit Nova manifold.
GP: Capricorn C03 1/10 touring, Capricorn C803 1/8 onroad
Engine: Tesla .12 WC, Tesla .21 7 port on-road, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 01-26-2012, 07:28 AM   #32
Originally Posted by kyosho malaysia View Post
yes,its marketing. picco,reds racing,sonic,vox,xceed and mega,all the specification are the same.
Mod works are silghly different, but the parts are interchangeable, I bought the Xceed conrod for Sonic, very cheap =P
Old 01-26-2012, 08:11 AM   #33
stefan's Avatar
Send a message via AIM to stefan
Not Vox, they are still based on P7R-Evo4....
stefan is offline   Reply With Quote
Old 01-26-2012, 08:13 AM   #34
stefan's Avatar
Picco Torque Edo modified has the teardrop and silicone in the shaft.
Picco Torque 2012 also has the balanced crank shaft....
Old 01-31-2012, 08:11 AM   #35
D-nicest's Avatar
Just to add on the Reds have matched piston sleeves similar to what max power does for novarossi. This and the work from rossi can help explain the price difference in the motors....
Diatta Collymore [email protected]([email protected])(www.fordhamhobbies.com) (Wallacemotorsports.net) Fordham Hobbies, Wallace Motorsports, WRC Racing, Hot Race Tyres, Ielasi Tuned Engines, VP Power Master fuel, KO Propo America, Paint By Mikey Mike
D-nicest is offline   Reply With Quote
Old 01-31-2012, 10:10 AM   #36
but picco toque EDO are with tear drop and silicon filled,must compare apple to apple(price)
kyosho malaysia is offline   Reply With Quote
Old 01-31-2012, 10:13 AM   #37
i means 2.11cc engine
and also i only mention picco not picco torque
Old 02-05-2012, 09:32 AM   #38
Default Sonic .12 problem
Any .21 Sonic user experienced:
-Carb leak? (Silicone sealant solved it)
-tapping noise from uneven torque on head bolt? (I tried many time to tighen the head, no help!!!!)
-Gummed in the pinch zone? (Not sure related to uneven torque on head bolt)
Old 02-05-2012, 10:16 AM   #39
quietstorm76's Avatar
Don't have a Sonic but I have the new IDM RCW Modified and I noticed the tapping noise too. It seemed to go away once the engine was warm so I didn't worry about too much. Still weird because it doesn't happen on the stock IDM RCW. They both are fast though so time will tell.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 02-05-2012, 07:47 PM   #40
I found the problem last night, I unstall the heat sink, and I double check all the bearings before reinstall the engine.
I found the head and sleeve have little movement in between, I have to carefully torque the bolts evenly. I think the head and sleeve is not align properly. Now, the pinch zone towards TDC is smoother.
Old 02-06-2012, 08:50 AM   #41
what u means(head and sleeve have little movement in between),thats mean leaking?
Old 02-06-2012, 10:13 AM   #42
GREGORY!'s Avatar
can someone put some photo from the parts of his engine?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 02-06-2012, 07:38 PM   #43
when I shake the head a little, it moves.
Old 02-10-2012, 05:35 AM   #44
They're not making the V21B yet? Man, that'd look great in an MBX6R.
SUPERFORMIAN is offline   Reply With Quote
Old 02-10-2012, 09:57 AM   #45
you means the heatsink not tighten equally.
QCRCCC OFF-ROAD RACING emer Manila Racers 16543 04-08-2016 01:31 AM
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 06:51 PM
OS VSPEC, OS TZ and Nova P5 Engines For Sale straycat40 R/C Items: For Sale/Trade 13 01-25-2010 04:02 PM
Hobao Fan Thread ket2175 Singapore R/C Racers 209 01-19-2009 07:58 AM
