-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   How many gallons before an engine becomes weaker. (https://www.rctech.net/forum/onroad-nitro-engine-zone/561602-how-many-gallons-before-engine-becomes-weaker.html)
fung_kyle 10-22-2011 11:49 AM
How many gallons can an engine go through before it loses it power, and when does the power increase?
THanks!!
asw7576 10-24-2011 06:28 PM
THanks!!
assuming you are in grup B : 30 minutes final + 3 x 5min qualifying
most power increase : usually your 3rd or 4th races
power decreasing : usually after 5th or 6th races
Complete engine rebuild or sell that engine after 5th or 6th races.
So I guess reaching 3 gallons is already considered lucky.
( I usually try to rotate the flywheel and feel the pinch. If it easy to twist, it means the engine is done. )
Roelof 10-24-2011 11:56 PM
It is all about brand, model production serie and how you are using it. In the offroad people are getting 10 gallons and still going strong, in the onroad 1 gallon can happen and 4-5 gallon is possible. Cheaper engines do not have stronger materials....
You can lengthen the live a lot with pre-heating the engine and change the rod and check the bearings on time.
