Old 11-25-2004, 05:42 AM   #1
Default Something burning in the back of my mind...
Something just occurred to me, what stops the conrod moving and rubbing on the backplate of a non pullstart engine??
jamiekulhanek is offline   Reply With Quote
Old 11-25-2004, 06:04 AM   #2
EdwardN's Avatar
Default Re: Something burning in the back of my mind...
Taper on cranckpin and vertical ballance of piston/conrod
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 11-25-2004, 11:25 AM   #3
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Default Re: Re: Something burning in the back of my mind...
Hey Ed, are you referring to the Wristpin is wearing out? not in perfect round?
Ah10 is offline   Reply With Quote
Old 11-25-2004, 11:43 AM   #4
cdelong's Avatar
the pin boss on the piston (look underneath piston) stops the rod from moving too far and contacting the backplate.
this is why it's sometimes hard to remove the piston/rod assembly from the crank on a fresh engine. the rod does not always move real freely on the pin in a fresh engine. there is just enough room for the rod to slide on the wrist pin and remove it from the crank.
cdelong is offline   Reply With Quote
Old 11-25-2004, 08:27 PM   #5
EdwardN's Avatar
Default Re: Re: Re: Something burning in the back of my mind...
Hey Tony. Actualy I am refering to cranckshaft pin.
Initaly there is negative taper-very small. This is why conrod is not sliding out. Ones it is wearing out-you can see results on back plate.
Corey you are absolutly right about some engines is very dificult to take on parts and it is due t the tolerances on cranpin and wrist pin. In airmodeling all high end engines for speed and pilon even procedure is very special to take piston/conrod is complaceted, First we taking out sleeve, tehn G-clip from exhaust windows, then frist pin, next piston and conrod. Assembling is opposit way-put conrod, put piston, put wrist pin etc. To put G-clip we made specila tool-it is pretty dificult to put that clip through the exhuast, but it is done and with exprience it is done within a second. BTW, I do use this tool for regular assembling too.
Tool look like very thin wall tubing. OD is 0.02 mm smaller then wrist pin and wall thickness is 0.03. I put G-clip inside that tubing and then slide that tool inside piston's wrist pin hole and pushing G-clip out side by the pin ( which is close size to ID of tubing)-G-clip is on it's palce. Very fast and never fail.
Old 11-26-2004, 08:34 AM   #6
thanks guys...
One other question, i am fairly new i guess to nitro engines, and bought an engine to replace my old one...
I pulled it down completely and cleaned and oiled it, but unlike my crappy GX 15 engine the O.S. has a hole or "window" in the piston, i was a little unsure of how to orientate the piston. It can either be installed with the window on the exhaust port side or on the booster port side, i reassembled the engine with the window on the booster port side. I hope i did the right thing...
I wasnt totally sure if the window was a port or weight balancing...
Please help
Old 11-26-2004, 10:37 AM   #7
EdwardN's Avatar
thanks guys...
Please help
Window on piston must to look on booster, not on exhaust.
ESC burning hot, car stalls uniquexme Rookie Zone 12 04-12-2006 02:39 AM
Burning oil Bad Seller !!! Ed Pasoquen Buyer/Seller dispute and Feedback discussion forum 10 05-18-2004 09:57 AM
I Keep Burning My Endbell ARV Rookie Zone 2 07-27-2002 06:25 AM
Burning Speedo Chat Lounge 23 04-25-2002 10:50 PM
