Throttle spring? / failsafe?
Hey guys, i just wanted to know what u guys are using as a throttle spring in the even that the receiver battery dies or the throttle linkage comes disconnected? Is a spring strong enough for the throttle if it's still hooked to a servo or do u guys use something else? thanks!
Kyle |
small rubber band. loop it from the HSN over the carb and hook it on the ball where your throttle linkage hooks up.
Get a set of small hairbands. They are a bit fuel proof and do work perfectly.
Be sure you have a smooth servo. Some standard plastic gear servo's are hard to turn by hand so a simple spring or rubber band will not work either. |
Originally Posted by Roelof
(Post 9664484)
Be sure you have a smooth servo. Some standard plastic gear servo's are hard to turn by hand so a simple spring or rubber band will not work either. You can get decent digital servos for a very low price (depending what you look at) online from hobbyking. |
Originally Posted by brothainchrist0
(Post 9664092)
Kyle |
I use these on .21 engines:
http://www.smg-speedshop.de/shop/pic...LMI20908_1.jpg http://www.smg-speedshop.de/shop/pic...e/LMI20908.jpg |
spring
Originally Posted by stefan
(Post 9668359)
(Post 9668359)
(Post 9664092)
Kyle |
These springs are also mounted standard on some kyosho and HPI cars. With a small search you can find the partnumbers.
(Post 9671576)
Here the Kyosho part:
http://www.kyoshoamerica.com/74023-2...1--_p_779.html |
| All times are GMT -7. It is currently 12:29 PM. |
