Crank cleaning
hi huys, i have an old engine that i need help with. it has some surface rust on the crank and i was wondering what would be the best way to get it back to looking new again.
Originally Posted by ugglasdav
(Post 9339951)
you can also use the green side of a dishwashing pad and some detergent. after cleaning, wash it down with some water and pop it into the oven at 100degrees celcius so it dries compeltely and doesn't rust again, then smear it with any light engine oil, or after run oil, or automatic transmission fluid. |
thanks tom, the dishwashing pad and detergent did a great job.
| All times are GMT -7. It is currently 01:19 PM. |
