How tight are your NUTZ!
Ok so I am just getting back into R/C racing and are starting back with TC's. Does anyone know how tight the flywheel nut needs to be that binds the collet to the pilotshaft? Thanks in advance.
I am afraid this is the common reason I hear about when people say they're clutch went out during races. I've tightened my flywheel nut about a quarter of a full turn after it was hand tight but need to know if I need to retightened it before I run the engine for the first time, its a OS .12TZ 5 port.
You want to fasten the nut around 20N/m of torque.
I appreciate that, thank you.
Originally Posted by Hi-Speed
(Post 9328983)
another helpful hint is to make sure u have the proper collet at times it maybe a bit longer & will hit the flywheel & will not be properly tighten & cause gap/endplay issues |
Hmmm I just used the one that came with the kit and the upgraded aluminum flywheel that was also included in the kit.
(Post 9359863)
Originally Posted by GMartinez
(Post 9362702)
Most of the time I use the kyosho collet vs what comes with the kit or the motor as it is always a bit long & using the shorter gets u closer to a better clearance from the flywheel to the engine
Originally Posted by dsond
(Post 9362723)
I always trim the collet with a dremel to get a good clearance.
| All times are GMT -7. It is currently 07:34 PM. |
