Old 09-21-2004, 08:38 AM   #1
Default Bottom coil of glow plug coils not glowing....
Hey,
I've noticed in my engine, that the bottom coil in the glowplug is going black very prematurely in the plugs life...And seems to make starting quite hard.
Recently I bought a BRAND NEW OS #8 plug and installed it, started it up, and everytime i removed the glo starter it would die, but i drove around slowly with the starter still on and it went fine...
So i put in an A3 and it was 100% fine...
It happens more rapidly with OS #8 than OS A3's
Anybody cluey on this?
jamiekulhanek is offline   Reply With Quote
Old 09-21-2004, 09:34 AM   #2
Regional Moderator
daniz24's Avatar
Are both turbo or non-turbo plug?
daniz24 is offline   Reply With Quote
Old 09-22-2004, 02:25 AM   #3
non turbo....i wasnt aware there was an A3 or #8 turbo plug...
Old 09-22-2004, 03:11 PM   #4
mo
mo's Avatar
Sounds like your low speed needle is set too rich. Try leaning it out about 1/2 turn and richen up the top end a little to help keep the engine temp down if you need to. You may also need to raise the idle speed if the carb is closing too much.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 09-23-2004, 08:07 AM   #5
Well, it's an RTR hunk engine, and there isn't a Low speed needle, just high speed.
Idle speed seems ok, doesnt stall, doesnt engage clutch...
I have a new OS .12 CV on the way, so hopefully this engine will be more user friendly...
What glow plug do i need? rockfordccinc Nitro Off-Road 2 01-29-2008 03:16 PM
Melting glow plug coils! performula Onroad Nitro Engine Zone 27 05-18-2007 05:51 AM
GLOW PLUG FOR RB S5 HELLOkitty Electric Off-Road 4 10-24-2005 10:46 AM
glow plug mark123 Onroad Nitro Engine Zone 2 07-10-2004 03:39 AM
Glow plug coil pushed in... what am I doing wrong? uDi_MP7.5 Onroad Nitro Engine Zone 3 06-20-2004 06:05 PM
