-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   Messuring engine timings (https://www.rctech.net/forum/onroad-nitro-engine-zone/503335-messuring-engine-timings.html)
Roelof 04-17-2011 12:16 PM
With new engines the brightness of the light does not matter much so far I have seen. the sharp edges of the ports and small tolerances is cutting the light as a sharp knive.
Indeed as you are mentioning I do have some small difficulties with rounded edges and the V-shape exhaust ports but indeed if you use a steady methode for it you will get far.
maxflo777 04-17-2011 02:20 PM
I use a depth gauge and a known thickness stopper. 100% consistent. ;)
xe
mtmmotorcycles 04-18-2011 03:54 AM
2 Attachment(s)
This is the setup i use, I find it extremly accurate, i do find that the key to accuracy is using a dull light.
ralphierace13 04-19-2011 04:25 PM
? whats the down side if u raise the timing 1 degree and its not good what happens, i mean does it get slower, ruff idle, hard to tune do u loose bottom end or top or it just dont get faster... thanks
