Old 09-09-2004, 02:21 AM   #61
compaq888's Avatar
Send a message via AIM to compaq888
Originally posted by RC Dumb
what the difference bettween 410 and 430 series?
410 is non turbo but with a slightly modified crank. 430 is turbo but a stock crank. non turbo runs cooler.
compaq888 is offline   Reply With Quote
Old 09-09-2004, 12:11 PM   #62
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
How is that possible?
Ah10 is offline   Reply With Quote
Old 09-09-2004, 01:01 PM   #63
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
The crankshaft and the case is different on the x12 versus the v12. The V12 uses larger bearings to support the larger crank. Because the bearings are larger they had to make the holes in the case larger. Not only that, but the V12 case is supposed to have some fins on it to make it stiffer. I have both engines, but haven't actually put them side by side.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 09-09-2004, 03:01 PM   #64
compaq888's Avatar
that is what I have been told by lots of people. I'm not going to argue with you about engines because i know you know your stuff.
Old 09-09-2004, 04:13 PM   #65
afm
afm's Avatar
We are talking about V12 engines 410 and 430, because there was a 410 and 430 on the old X12 series.
So in the new V12 series the difference is that 410 is Std head (for normal plugs) and a crank without turbo scoop. The 430 has a turbo head (for turbo plugs) and a crank with turbo scoop. Other than that, the rest is exactly the same...crank timing, sleeve porting and timing, etc. etc.
The difference between old X12 series and new V12 series is that the old series had the 11mm crank and no milling of the base of boost port on the crankcase. The new series has 11.5mm crank and milling on the base of boost port of crankcase, and new series gets different crank bearings, front is smaller in external dia. and rear is bigger in internal dia. so crankcase is different size too.
AFM
afm is offline   Reply With Quote
Old 09-09-2004, 04:16 PM   #66
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
seems like they're mixed up here, according to afm.
eddiethefish is offline   Reply With Quote
Old 09-09-2004, 04:32 PM   #67
AMGRacer's Avatar
That is not true.
AMGRacer is offline   Reply With Quote
Old 09-09-2004, 04:47 PM   #68
Ah10's Avatar
Originally posted by eddiethefish
I run RB Rody X12 5-Port and still slower than compaqboy's on the straight. My gearing is right, but just not any faster...
come to think of it, 5 supposed to be faster than 3 on the straight, but it isn't!
How hot were you running and what kind of plug and what gearing?? and tire side? (front to back) are you running overdrive and such?
Old 09-09-2004, 05:54 PM   #69
I was trying to run only on the 1st gear as he does, but failed. All the cars passed me. I was just wondering why my engine is not that powerful as his.
Old 09-09-2004, 06:10 PM   #70
thanks, afm.
AFM
RC Dumb is offline   Reply With Quote
Old 09-09-2004, 06:58 PM   #71
mckrooz's Avatar
Send a message via AIM to mckrooz
I smell sarcasm.
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 09-09-2004, 08:37 PM   #72
compaq888's Avatar
I smell jealousy.
Old 09-09-2004, 08:57 PM   #73
Default x12 340
Does anyone have any info on the RB x12 Rody 1700-000340?
raceblast is offline   Reply With Quote
Old 09-09-2004, 09:42 PM   #74
compaq888's Avatar
Default Re: x12 340
www.rbproducts.com
go to that website.
Old 09-09-2004, 10:03 PM   #75
I cannot find info on RB 340 at the RB web site! Just wondering if anyone knows this engine?
