Old 08-30-2004, 05:52 PM   #1
Send a message via AIM to Bxclip
Default mugen x12 manual online
i need the manual for it online.
Bxclip is offline   Reply With Quote
Old 08-30-2004, 06:26 PM   #2
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
There is no "manual" Only two sheets that include an parts list and an exploded view. If you need either of these, give me your email and I will scan them and send them to you that way.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 08-30-2004, 06:26 PM   #3
which one is the idle screw low speed and mid range?
Old 08-31-2004, 10:35 AM   #4
is 20% gs good for this engien or what shoudl i use?
Old 08-31-2004, 11:58 AM   #5
Trader Rating: 16 (100%+)
Wait.....are you talking about the setting of those needles? Or you are asking which one is which?
Old 08-31-2004, 12:45 PM   #6
firs twhich one is which and settign mtie helplol and yo how long does this engien surpose ot last liek in how many gallows of 20% fuel?
Old 08-31-2004, 01:49 PM   #7
packetdreamer's Avatar
Send a message via AIM to packetdreamer
OH... remember, you don't want to touch those needles too much on a new engine. depending on your breakin method, you may have to just open the hi-end needle 1/2. but that varies, so do as much research as you need so you don't hurt the engine too bad
late!
packetdreamer is offline   Reply With Quote
Old 08-31-2004, 06:10 PM   #8
thanx but what break in method should i use? im no sure i need help and hwo shoudl i adjust the needles to that break in method?
Old 09-01-2004, 09:52 AM   #9
Trader Rating: 15 (100%+)
Send a message via AIM to James Y
I use a heat treat method.
I'll wrap foil around the head and let it idle for one tank @ about 180* F. Let it cool for 15 min (remember to move the piston to the bottom). Then I'll run it for another tank going WOT @ about 200* F. Let cool for 15 min. Then just keep doing the same for about 4-6 more tanks.
Take off the foil and you'll notice it runs too cold. This is when I start leaning it out to about 200* F.
Well, this is how I do it and it seems to work for me so far. You might want some other suggestions though from the pros.
James Y is offline   Reply With Quote
Old 09-02-2004, 07:32 AM   #10
your method is not far from the one that i have adopted . bxclip. notice that that method requires a temp gun of some sort. fortunately there are some relatively inexpensive options on the market.
Old 09-02-2004, 09:57 AM   #11
wheres the cheapest temp gun?
Old 09-02-2004, 09:58 AM   #12
do i do this witht he wheels of the ground or what?
Old 09-02-2004, 10:03 AM   #13
i don't know exactly where, but your lhs or ebay may help. duratrax makes one, but there is another company (i forget the name) that has the same exact unit - less the duratrax logo - for about $25-$30. they give you a metal case and an extra battery too.
Old 09-02-2004, 10:34 AM   #14
so put foil on geine
dam thi car is comin otu to cost mroe htne expected now i need a temp gun
Old 09-02-2004, 11:05 AM   #15
Rapid Roy's Avatar
No you don't "need" a temp gun. Just don't let it get too hot. You can touch the head lightly from time to time to check the temp. Or just a dropper with water and put a drop of water on the head. The water should not boil since it boils at 215 degrees. You can set your oven the 200 degrees before and use that to see what it feels like. Remember, a light quick touch is all it takes. Then rub your fingers together. You won't feel the heat much until you rub. Do this at your own risk. I have used this method before without burning myself
Rapid Roy is offline   Reply With Quote
Mugen MRX-3 Manual? waipahe Nitro On-Road 0 08-28-2008 12:35 PM
Kyosho TF5 manual online? johnnyboy Electric On-Road 2 10-15-2007 10:53 AM
Online Manual For AutoScore System ROBORAT Electric On-Road 2 11-07-2005 11:55 PM
Manual for Mugen X12 JLMG1971 Onroad Nitro Engine Zone 1 04-18-2005 09:15 PM
Looking for an online manual for the Airtrontics Caliber 3p hitman Electric On-Road 0 12-06-2001 05:19 AM
