Old 09-06-2004, 07:09 PM   #16
Trader Rating: 15 (100%+)
Send a message via AIM to James Y
the first tank (idle @ 180*), i leave it on the starter box with the wheels off the ground.
the second tank through 6+ (run WOT @ 200*) i'll take it to a track or a parking lot that I sweep (little rocks are bad for your car). it doesn't have to go WOT the whole time, but I do try to get it running at 200* as much as I can. You might need a big parking lot for this. I prefer the nearest college with the less dust/pebbles.
and no, you don't need a temp gun. you can do the water drop as mentioned below or spit on the glow plug. Make sure you check the temp at it's hottest (right after going WOT for a few seconds).
hope this helps.
James Y is offline   Reply With Quote
Old 09-06-2004, 07:12 PM   #17
oh yeah. after breaking in, you might want to change out the con rod.
if your engine is hard to start at first, heat it up with a heat gun. also, before you put it on a starter box, you'll want the piston on the bottom and not at the top.
Old 09-06-2004, 07:48 PM   #18
Send a message via AIM to Bxclip
ok thanx now the car is built jsut no radiop yet eninge is ont he clutch spins both ways but when i install the engien i can push the car forwards btu now back wards its liek the gears stop its on a 710
Bxclip is offline   Reply With Quote
Mugen MRX-3 Manual? waipahe Nitro On-Road 0 08-28-2008 12:35 PM
Kyosho TF5 manual online? johnnyboy Electric On-Road 2 10-15-2007 10:53 AM
Online Manual For AutoScore System ROBORAT Electric On-Road 2 11-07-2005 11:55 PM
Manual for Mugen X12 JLMG1971 Onroad Nitro Engine Zone 1 04-18-2005 09:15 PM
Looking for an online manual for the Airtrontics Caliber 3p hitman Electric On-Road 0 12-06-2001 05:19 AM
