Pixy black Carb settings
Soem1 now a good carbsetting??
Running 16% nitro and O.S. A3 glow plug AirTemp is 68F .. |
Check the team trinity website. They tell you that your needles may end up after break in. Check under nitro stuff and tech tips on the page.
www.teamtrinity.com Hope this helps. Tony |
Cannot find anything good sry :cry:
Some1 pls. need help !
Found :lol: but what does they mean with flush with carb body??
Flush with carb body, usually means that the screw head is even with the housing of the screw.
High speed needle... 5 turns out
Mid-range needle... flush with carb body.. DON'T TOUCH THIS ONE low speed needle... 3 turns out These settings will be alittle on the rich side and you can tune from there. There is no one set needle setting... Base settings are to get you close, then you fine tune from there... Run the car and see what the engine is telling you. Any smoke coming from the stinger, is temp to low, is the temp to high, does the engine shut off when I pull the trigger??? A good racing temp for that motor is 230* "F" Set your low speed first by leaning it until it doesn't shut off when you pull the trigger from being to rich... Also pinch the full line... You should have a 3-4 sec count before the engines shuts off... Now start tuning the high speed needle for speed and power... Always check that you have smoke coming out of the stinger from the pipe and your engine temp is not over 200* "F"... Remember, driving the motor easy will not bring your engine temp up... Only when you drive it hard and at speed will the temp go up. Not sure what the temp is in your area of the world nor if your engine was broken in properly... I have a 3 port black pixy and also a 5 port black pixy... Never had a problem tuning them and my carb settings are rock solid... Hope the info helps and the base settings will get you close... RC_Alan |
Yeah that should work I am just waiting for my starter box batt .. Maybe its here now .. :batman:
| All times are GMT -7. It is currently 05:09 AM. |
