fantom carby settings.
hi, does anyone know what the factory settings are on the Fantom FR12 Rear Exhaust motor?
Not sure what factory settings are but if put the main needle at 2.5 turns and bottom at 1 turn + 1 hour out from closed for rotary carb, then think 1.5 turns out for slide carb turns out from closed should fire right up and be real close.
i just rebuilt my motor and im wondering what settings i should run the needles at for break in
Whenever I break a motor in I just keep the bottom needle same as "race tune" then the main needle is same or only 1/8" richer than when tuned right. I just don't drive the engine that hard keeping rpm down until loosens up some during break in, once loosened up and have solid polished ring top of the sleeve then good to go.
| All times are GMT -7. It is currently 01:28 PM. |
