Old 02-13-2011, 04:46 AM   #1
NiTrO BoOsTeR's Avatar
Default RB 10rc Factory needle settings
Hey guys i got a air leak on my mid (spray bar) needle and need to replace them. i wont to be sure i have got it in the right position does anyone now the exact amount of turns from closed they should be from factory as im not 100% sure mine is set right. i haven't touched it but maybe some1 who has helped me tune it has
Thanks guys i really appreciate it.
Mitch
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Old 02-13-2011, 05:17 AM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
Flush is mostly a good starting point.
From there the engine must start and depending the fuel and exhaust the LSN should be a full turn turned in and the main needle a halft to a full turn.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 02-13-2011, 05:33 AM   #3
thanks mate i really appreciate it, i would hate to get it wrong and ruin a awesome engine
mitch
Old 02-13-2011, 06:51 PM   #4
Factory settings are 5 turns out from closed on the high-speed end, 2+1/2 turns on the LSN, mid speed/idle bar is flush with the housing - line should run parallel to the carb.
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
Old 02-14-2011, 02:18 AM   #5
cheers guys just wanted to check.
Mitch
