-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   Cleaning inside the engine (https://www.rctech.net/forum/onroad-nitro-engine-zone/481362-cleaning-inside-engine.html)
N#1 03-17-2011 10:10 PM
as for cleaning the black only on top of the piston use toothpaste dab libererally on let sit for a bit then polish off in a circular motion
Maximo 03-19-2011 07:11 AM
I use a water based de-greaser in my heated ultrasonic.... Gets the engine sparkling clean !
jakerz 03-22-2011 08:46 PM
Fuel works good. I have a liter jug of fuel that I use specifically for engine cleaning (20% nitro, 16% oil) The nitro will free all the gummed up parts and old/built up oil and carbon in the engine and the oil in the fuel will coat all the parts and ensure no rust happens. You can get in there with some q-tips and pipe cleaners to get the really gummed up stuff off. Just dont do any scraping or rubbing to the piston skirt or the inner part of the sleeve.
DJ_Shakespear 03-23-2011 12:51 AM
The part in bold is true, if the oil is used on it's own. Otherwise we would not need to remove as much fuel as possible after running, or before storage - because the the nitro is 'Hydroscopic' (correct spelling or word?) meaning it attracts moisture from the air?
Anf 03-23-2011 03:19 PM
Methanol is hygroscopic.
stefan 03-23-2011 03:56 PM
Both, methanol and nitro methane are highly hygroscopic...
Anf 03-23-2011 06:21 PM
Perhaps you did not understand....
Roelof 03-24-2011 12:15 AM
Even the most synthetic oils are a bit hygroscopic
DJ_Shakespear 03-25-2011 03:09 AM
Thanks guys, I thought it looked a little wrong :p
robertsander08 07-05-2022 06:25 PM
Car maintenance shouldn’t just be as superficial as keeping your car looking clean and good on the surface. You also have to clean its internal engine parts to prevent the buildup of sludge, grease, dirt, rust, etc.
1995 Monster T 07-06-2022 06:48 AM
The black stuff is from not enough oil lube. and high nitro content. Add more oil lube and you will be fine.. All my engines are clean from using the correct amount of oil lube 18%. You can clean it off with oven cleaner and a scotch brite pad.
Roelof 07-06-2022 08:31 AM
The black stuff is for a part a burn of the dirt in the castor oil because castor oil is hard to get pure and for a part the burn of the oil itself.
Has nothing to do with a low oil or an high nitro content to do. Well..... for a part. If you run a high compression with a matching cold plugthen there is a slight cleaner burn.
