Picco 2011 TORQUE onroad engines
#331
Now that ya mentioned the time sheets, I'm curious to see how many laps I had on ya ping pong.
#333
#334
Is the conrod for the Torque EDO .21 the same as the p7r EVO4 EDO ?
#335
Anyone mounted this engine in a 966? Flywheel seems to sit very close to the crank bearing. Using the shortest flywheel cone otherwise I cannot get pinions on without it binding. Anyone done this?
#337
Hey guys, i jus got myself a Picco Torque .21 Edo Modified. Hope it doesn't disappoint...
Quick question, when would it be advisable to change the conrod? I'm planning to break in by idling 1 tank, and maybe run in on the track for about 8 tanks (intervals of cos) and after that, maybe push it through a race weekend before changing the rod.
What do you guys think?
PS. I forgot to mention i run a high speed track with a long straight that is about 80m.
#338
We have seen a few engines going south because of this.
After they made room with a dremel, all was good.
#339
I would skip the tank idling and start running the engine with the factory settings for two tanks. Let it cool down to ambient temp between the tanks.
From the third tank on, you can start leaning it for another two tanks.
After 4 tanks you can go for race tune.
Don't worry, if the engine looses all the pinch soon, according to Edo, it's gotta be like that.
We got 3 Torque that all feel like they are through, but they all run awesome.
#340
You'll find, that the new Picco engines don't need that much breaking in.
How about the conrods? there are 2 back to back races where i'm from in asia in Sept & Oct and i would like to keep my engines race ready. Do you think i have to worry about the conrods?
At how many gallons did you guys change ur conrods?
#341
Hi Stefan, sounds great. I'll give that a go...
After that, if nothing like overheating happens, we run the rods for 8 litres (2 Gallons)
#342
Does anyone know if the rod is the same as fitted in previous engines or any other Picco variants, IDM, Xceed etc?
#343
#345
