Old 06-21-2011, 02:37 PM   #256
Default muflers
What about these muflers has anybody tried them?
You can search them at eBay with their titles:
Picco (#P7-7741) 2002 In-Line On-Road Long
Picco (#P7-7701) 9897 In-Line On- Road Long
dsond is offline   Reply With Quote
Old 06-22-2011, 12:12 AM   #257
stefan's Avatar
Send a message via AIM to stefan
Originally Posted by wingracer View Post
Picco plugs are excellent, stick with them if you can. Also LM plugs (Sirio, Werks, Orion, etc.) work great.
and IDM.
That's because they are all from the same manufacturer
stefan is offline   Reply With Quote
Old 06-26-2011, 08:04 AM   #258
ugglasdav's Avatar
does anyone know the stock settings for this engine? thanks
>Shepherd Velox V8/Team associated TC5R
>>IDM 2011/ Speed passion/Much More
>>>Sanwa m11x
ugglasdav is offline   Reply With Quote
Old 06-28-2011, 07:07 AM   #259
ugglasdav's Avatar
?? anyone got any ideas
>>>Sanwa m11x
Old 06-28-2011, 07:19 AM   #260
M7H
M7H's Avatar
Originally Posted by stefan View Post
and IDM.
How come then that Sirio plugs glow much brighter then others?....
At least, last time I checked.....
Serpent
M7H is offline   Reply With Quote
Old 06-28-2011, 07:20 AM   #261
M7H
M7H's Avatar
I would say,
HSN, flush with housing.
LSN 1 mm outside housing.
Serpent
Old 06-28-2011, 07:24 AM   #262
Grinder's Avatar
Both needles should be flush with their housings. Then turn them both in one half turn. That is the stock setting, which is very rich.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 06-30-2011, 09:30 AM   #263
X4
X4's Avatar
Hey guys, does anyone have any experience with a Picco Torque Edo Modified with a nova 2015 pipe and 6 fin manifold? How does the nova pipe perform compared with picco's 2033?
I'm thinking of getting this engine but not sure if i should get the pipe set with it or should i jus use the nova 2015 which i already have.
Thanks!
X4 is offline   Reply With Quote
Old 06-30-2011, 02:53 PM   #264
Grinder's Avatar
Thanks!
The 2015 works great with the engine. It feels very similar to the Picco 2033.
Old 06-30-2011, 02:57 PM   #265
GMartinez's Avatar
Trader Rating: 85 (100%+)
Thanks!
I felt running it made it a little more crisp & really liked how it felt overall
Will be testing out the stdandard version this weekend if mothedr nature will play nice
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 07-01-2011, 06:06 AM   #266
X4
X4's Avatar
Thanks Grinder!
Old 07-02-2011, 06:00 AM   #267
ugglasdav's Avatar
hi guys, just having abit of a problem with my engine that i need help with, i have both needles one the engine rich with loads of smoke, but when i come in to pit it gets really lean. but when i go to pull off again its still rich. i think it may be the fuel tank or something in the car, becouse there seems to be vapour coming out of the tank when the car goings into idle. could you guys apinion on this problem. thanks
>>>Sanwa m11x
Old 07-02-2011, 06:18 AM   #268
walo's Avatar
Send a message via Yahoo to walo
You may have an air leak some where. (1) You can change the tank, (2) check all fuel and exhaust lines, (3) check carb to make sure it is sealed tight, (4) open both needles to riches point and retune.
walo is offline   Reply With Quote
Old 07-04-2011, 01:05 AM   #269
M7H
M7H's Avatar
Is it lean, or is it idling very high?
if so, lean the bottom end, yes lean the bottom end, and lower the idle, maybe even with a full turn...
Serpent
Old 07-04-2011, 03:31 AM   #270
ugglasdav's Avatar
thx guys got it sorted out
>>>Sanwa m11x
