Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Picco 2011 TORQUE onroad engines >
Old 05-03-2011, 02:17 PM
  #166
kmh
Default New Picco .21
Hello everyone, I just received my Picco Torque .21 EDO motor. Should I add a Shim for 25% Nitro and also do i have to use a washer under the plug? Thanks in advance.
kmh is offline
Old 05-03-2011, 03:22 PM
  #167
M7H
M7H's Avatar
You can if you like, depending the track size you run.
Is your track small, keep it as it is, if the track is bigger, add 0.1mm.
are you serious!
NO!...
These plugs are so called "turbo" plugs, they have a conical end.
M7H is offline
Old 05-03-2011, 07:32 PM
  #168
quietstorm76's Avatar
What's the stock head shims? .4mm?
quietstorm76 is offline
Old 05-04-2011, 05:48 AM
  #169
kmh
Ok Thanks for the info. I had an old picco plug that did'nt seem to seat right. But I have never used a washer with a "turbo plug". Will order new plugs. Thanks!
kmh is offline
Old 05-04-2011, 07:18 AM
  #170
ugglasdav's Avatar
anyone know what the differences are in these two manifolds that come with the picco 2033 pipe http://www.rc-mushroom.com/product_i...ducts_id=20270 and http://www.rc-mushroom.com/product_i...ducts_id=20158 thanks
ugglasdav is offline
Old 05-04-2011, 08:30 AM
  #171
kmh
Yes, part # ...7726 is the conical manifold the other is not. Conical= better power band, Non-conical is better fuel economy. Maybe someone else can provide more detail.
kmh is offline
Old 05-04-2011, 02:27 PM
  #172
kmh
The exploded view(parts sheet) shows part#2014- 0,1mm and #2068-0,2mm.
kmh is offline
Old 05-09-2011, 04:01 AM
  #173
Any shop in USA selling the new Picco engines? How come I still don't see any, it has been released like over a month already? The new Nova is too expensive now. I want to get something cheaper in price at the same fast performance.
ioxqq is offline
Old 05-09-2011, 05:25 AM
  #174
Grinder's Avatar
We will have them in about one week.
www.murnanmodified.com
Grinder is offline
Old 05-13-2011, 04:35 PM
  #175
Grinder's Avatar
The Picco Torque .21 engines are in stock now.
Grinder is offline
Old 05-14-2011, 09:30 AM
  #176
GMartinez's Avatar
Trader Rating: 86 (100%+)
Default Superior Hobies Instock
The .21 Picco Tq Edo Modified Power Pack are in stock .12 on arrival
http://www.superiorhobbies.com/istar...&id=PIC9231!SH
GMartinez is offline
Old 05-15-2011, 09:39 AM
  #177
whats factory needle settings for the .21 ?
yappy is offline
Old 05-20-2011, 07:00 AM
  #178
Grinder's Avatar
A good base setting for the .21 Torque is as follows.
High Speed Needle = 3 turns out
Low Speed Needle = 4 turns out
This is flush with the housings on both needles.
The factory settings are 1/2 turn leaner than what I have listed above.
For break in, I would start 4 turns out on the LSN, adn 4 turns out on the HSN.
Grinder is offline
Old 05-20-2011, 10:30 AM
  #179
Grinder's Avatar
Default Technical Support
Please feel free to direct any technical support questions regarding the Picco Torque engines to me. You can contact me at the following email address, or just ask on this thread.
[email protected]
or
[email protected]
Grinder is offline
Old 05-20-2011, 10:50 AM
  #180
Thanks for the info
Question, how do make my Picco super duper fast like yours at the Worlds?
