-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   Need some help with engine mods...... (https://www.rctech.net/forum/onroad-nitro-engine-zone/47217-need-some-help-engine-mods.html)
jamiekulhanek 08-08-2004 08:54 PM
Hey all,
I need some help with my engine, it's just a basic sport engine which came with my Ultima RB.
Anyway, i disassembled the carb to clean it out, and noticed that the barrel in the carb has a 4mm throat (!!). The inlet of the carb is 6mm....but the throat is tiny!!
I see this as a big restriction, and i plan to bore it out to 5-5.5mm......can anybody give me any tips or suggestions as to how i should go about this, and any problems i may get from doing it?? I'm also going to remove 1 head shim to try and raise compression, will i need a different glow plug if i do this??
I have added a tuned pipe, and matched andpolished the exhaust manifold. I also added a higher flow filter than the stock one, and oil and clean it regularly.
I am starting an offroad buggy club (we have an unused BMX track to race on) and i will be racing mainly agains other RTR's such as Evaders (.18 O.S.), and want to better my chances of keeping up.
Thanks in advance,
Jamie
jamiekulhanek 08-08-2004 08:56 PM
BTW its a kyosho GX15 CRG
jamiekulhanek 08-17-2004 03:38 AM
bump
FFR3582 08-18-2004 06:58 AM
The carb hole is suppose to taper, if you drill it out to the same bore with no taper you will hurt performance. The taper is called a venturi, the air speed increases as it enters the carb becasue of this taper, leave it alone.
Sounds like you are about to mess up a good motor.
jamiekulhanek 08-19-2004 06:48 PM
The thing is it doesn't taper......it goes from 5.5mm, to 4mm (barrel)instantly, like a big step, then the bottom part of the throat between the engine and barrel is 4.5-5mm. so this means that the air accelerates through the barrel (4mm) then loses velocity when it goes into the tube leading to the crankcase.....
I haven't done anything yet.....
jag 08-20-2004 05:30 AM
Are you sure you are not missing the insert (restrictor)?
jamiekulhanek 08-22-2004 10:23 AM
There is no restrictor for this carb...
