-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   Replacement bearing for Novarossi (https://www.rctech.net/forum/onroad-nitro-engine-zone/471062-replacement-bearing-novarossi.html)
fulcrum2 01-14-2011 01:12 AM
Hi there,
I need a replacement for a Nova 17008 (7x19x5mm), but need rubber shields.
Does anyone know where I could get one?
Thanks a lot and best regards, Stefan
DJ_Shakespear 01-14-2011 02:50 AM
Originally Posted by fulcrum2 (Post 8485697)
Hi there,
Check out Boca Bearings or Acer Bearings, they will have what you need and it should be cheaper.
Roelof 01-14-2011 03:00 AM
The 7x19x6 is a standard size bearing you can order at any bearing manufacturer even companies like SKF and INA but the 5mm thick version is difficult.
fulcrum2 01-14-2011 03:52 AM
...but the 5mm thick version is difficult
I know! Still working on my rain car for the new season. The chassis is ready by now, but I still look for solutions to "waterproof" the engine.
If I can not find a "RS" type front bearing I will run a buggy engine instead...
Roelof 01-14-2011 04:35 AM
Buggy engine in the rain is no problem, the preformance with an onroad exhaust is quite good, I have runned a WS7-II on short tracks.
Maybe an idea to find another crankcase and crankshaft with normal bearings?
fulcrum2 01-14-2011 06:19 AM
Thanks for all your advise Roelof, much appreciated.
Will try the buggy engine for sure.
On the other hand, I have two worn out 35+21 based engines. They got the 7x19x5mm bearings with metal shields. Would you run them in the rain, or is it senseless to try without rubber shields?
On more question: How do you "set-up" a rain engine? My strategy so far: head gap like normal (0.7mm), very hot plug (5 or 6), lexan under the motor mounts and aluminium foil around the cooling-fins. I know a shorter cooling head would keep the temps up nicely, but sometimes the track dries during a final and then you are glad when you just can remove the foil and adjust the carb for better performance.
Thanks again, Stefan
Roelof 01-14-2011 09:11 AM
Normal 35+ has the 6mm bearing, the older ones for sure.
Rain setup for an engine:
- place a piece of lexan between chassis and engine mounts
- use a small head (I have an Novarossi airplane engine head)
- use plug 5 with normal headclearance and have some spares in the pit
- use an INSBOX with a cut off airfilter (no filter)
wingracer 01-14-2011 09:44 AM
Yeah I thought so. Both of mine are 6mm. They are older blue heads though.
maxflo777 01-14-2011 01:53 PM
I have a Cordoba WC (C1/C2 rod) and although I have not removed the bearing, the crank shaft has a longer valve/midsection than that of a standard buggy 14.5 crank, like a Toro Nero ,367, FMS, plus 21-5, 21-7 etc, which I know for a fact that the front bearings are 6mm wide, maybe its a 5mm I don't know for sure...
xe
fulcrum2 01-14-2011 11:49 PM
On the 35+21 based Cordobas and on the newer 35+21 they use the Nova part 17008 which is 7x19x5
