Old 12-25-2010, 02:59 AM   #1
g-wan's Avatar
Send a message via MSN to g-wan Send a message via Yahoo to g-wan
Default rally and on road engine different
hi,may i know is there any different on both of the title above?as im ordering 1 of the kangaroo engine,but coming is kangaroo rally..so wish can any one here can explain the diff
km k8 / os speed / savox / blitz / contact tyre
km hk1 evo / os speed / savox / sweep
sworkz evo / spower evo s7 / sweep / savox
xray t3 2012 / tekin rs pro / reedy / savox
km racing / sworkz / xray / savox / sanwa / os speed / sweep / ulti / blitz
g-wan is offline   Reply With Quote
Old 12-25-2010, 12:29 PM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
I can not tell from experience but I can imagine a Rallygame engine is something in between of an offroad and an onroad. More rpm than an offroad but still more torque than an onroad.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 12-25-2010, 08:34 PM   #3
g-wan's Avatar
hope those engine same with the on road engine as my friend ever try toro nero on his 1/8 on small tight track,but is it the same performance or different on off road and on road engine?some say off road engine can be use to on road,but some say the crank shaft/ conrod will broke due to stress once on the straight..
Old 12-26-2010, 05:16 PM   #4
That could be because of over-revving the engine.
Offroad engines produce less RPMs, say up to 35,000.
Onroad engines can make past 50,000 under no load, but when in a car the usually make 40-45,000 RPM.
Offroad have more torque whereas onroad has more RPM and I think a higher Peak HP, as well as a more broader power curve.
I would say that you could use an offroad engine for on-road, but I wouldn't because they aren't made for that kind of use, and because you would have to gear it up higher so the engine doesn't top out and over rev.
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
Old 12-28-2010, 01:19 PM   #5
Nah, they wont break, they'll just be slow. Say that toro nero your friend is running, it has the same rod that a flash tuned has, it is balanced and the materials are top notch as the flash, its just timed for a different purpose. The engine will have less HP, less torque, the torque will be spread wider across the performance curve with less spikes and a considerable amount of the torque will be attainable lower in the rpm range. All this because that's the best way to go fast in a comparatively slippery, tight, off road track full of hairpins and off the curve jumps
Unless you lean the mixture looking for power that is not there the engine will not break. if you go to lean you take away from the needed lubrication. The forces of an engine at 30 ~ 35k rpm are WAY less than the forces of an engine at 40 ~ 45k rpm. These forces are exponential.
maxflo777 is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 11:20 PM
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 06:51 PM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 01:03 AM
on road engine in buggy omarwashington Nitro Off-Road 12 04-13-2009 06:39 AM
